FH9HVX - Budget Conscious 100w Class AB for Lean Times
Hi X,
Thanks for the explanation. Since I would be happy with around 100W of amplifier power, I think that the AN3436 is what I will use. It is a good compromise between $ and Watts output. Antek is not doing any custom work according to their website, so the only other transformers listed is the AS4438 and AS4440 which are both 400VA models, but they are approx 1.5 X the price of the AN3436. It would be nice to have the 400VA / 38V model, but not sure if the extra cost is warranted. I think the 40V is too high?
I have a memo in with Antek, asking about shipping costs to Canada, as the US depot I was using in Idaho, is off limits now due to C-19, so shipping fees, duties, tax, will be more. Such is diy!!
Happy independence Day, and be safe.
MM
Hi X,
Trying to put together a BOM for the All C's pcb. Tried uploading the JPS bom to Mouser, which was an epic fail, so going thru the schematic and stuffing guide to populate a soreadsheet from Mouser. Question:
" What is the lead spacing/pitch for the small capacitors from C101 through C132 ". I look up the caps, but do not know the lead spacing. I would like to order the parts while waiting for the pcb's.
Thanks for the help,
MM
Hi Myles,
The package notation that JPS64 uses is basically pin pitch in mm x width in mm. Width is the size perpendicular to the axis of the pins in a radial package. For the round electrolytic caps, it is pin pitch in mm x dia in mm. For SMT it is length x width in 10mils (ten thousandth of an inch: 1206 is 0.12in long x 0.06in wide). Here is the BOM for the cap sizes listed in detail using the above notation.
Code:
Part	Value	Device	Package	Package Size
C101	0µ01	C7.5/3	C7.5B3	7.5mm pitch, 3mm wide
C102	0µ01	C7.5/3	C7.5B3	7.5mm pitch, 3mm wide
C103	0µ1	MKP4F031002D00JF00AUDIO	C7.5B5	7.5mm pitch, 5mm wide
C104	0µ1	MKP4F031002D00JF00AUDIO	C7.5B5	7.5mm pitch, 5mm wide
C111	2µ2	C5B11	C5B11	5.0mm pitch, 11mm wide
C112	2µ2	C-EUC1210K	C1210K	SMT 1210
C113	2µ2	C5B11	C5B11	5mm pitch, 11mm wide
C114	2µ2	C-EUC1210K	C1210K	SMT 1210
C115	10000µ	CPOL-EUE10-30	EB30D	10mm pitch 30mm dia
C116	10000µ	CPOL-EUE10-30	EB30D	10mm pitch 30mm dia
C117	10000µ	CPOL-EUE10-30	EB30D	10mm pitch 30mm dia
C118	10000µ	CPOL-EUE10-30	EB30D	10mm pitch 30mm dia
C121	0µ22	C15/5	C15B5	15mm pitch , 5mm wide
C122	0µ22	C1206C106K4RACTU	C1206	SMT 1206
C123	0µ22	C15/5	C15B5	15mm pitch , 5mm wide
C124	0µ22	C1206C106K4RACTU	C1206	SMT 1206
C131	0µ022	885342208014AUDIO	C1206	SMT 1206
C132	0µ022	C5/4.5	C5B4.5	5mm pitch, 4.5mm wide
Thank you for this.
Selecting a component with incorrect lead spacing has stuffed me up more than once.
From that, I now tend to hold off on parts orders until I've got the board in hand so that I can measure distances directly. That way, no mistakes.. :cheers:
Hi X,
Just to confirm I have this correct. The pitch is the distance between the leads, and the "wide" is the actual width of the component, excluding the SMT components which are as you described. Hopefully not confusing you?
MM
