F6 Illustrated Build Guide
Official Court Jester
Joined 2003
there are so many parts inside ....... best to check them all , at least visually :)
after JFets, R3 and R4 being first candidates, ref. to schm Jim posted in #1
with power off, after visual inspection of all parts, waste some time fiddling with ohmmeter - checking all resistors m comparing good and bad channel
most of measurements will be inconclusive (absolutely) with parts still in circuit, but maybe somewhere you'll spot a difference between channels
I figured out my problem.... one of my 1000uf caps had a broken leg from me trimming/bending it to fit the board.. after replacing it the right channel now matches the left.
This cap I had to move around quite a bit to install the trimmer pot so I know that’s how I snapped it.
Amp sounds great and biased fine to .6V. I may try .65V after letting it play for a week.
I would like to say thank you to
Nelson Pass,2picoDumbs,meanie,6L6 and people who support for build and
diyaudio forum.
I could not build without support but learned a lot from trouble,also apologize for my mess.
Now my fullranges sounding fantastic. Biased 1.5A
Vocal is soft and smooth and slapping percussions tight.
I have changed some parts for my taste,still waiting for Panasonic erx.
I also addicted to build so I ordered aleph J and Ba-3 PCB...
