F6 Illustrated Build Guide
Wow!!!!! Reminds me of the 1968 hit film 2001 Space Odyssey! I wonder how warm your heatsinks are, you definitely have enough. Just 110 deg Fahrenheit which is 43 degrees Celsius, very cool. I'm using 5U case myself since I see myself building other NP projects.
Enjoy and let us know what other gear you have besides the KEF Speakers.
Best,
Anand.
jdg123: Wow, a thing of beauty. I can appreciate all the hard work you did making that custom enclosure. When I started my custom Cubie3 amp, I knew what I wanted to look like, but about half way through, I began to doubt if it was worth all the work. When done, I am glad I did. You now have a beautiful amp you can be proud of for many years, along with enjoying the beautiful sound, and it should be an inspiration to other would-be builders.
Wow, guys, thanks! I'm just getting home from a crappy day at work and all these kind words wash away that dirt!
I very much enjoy this building of amps. I could not do it without all the generous help I get when I get confused on the inner, working parts. And the man himself helped me out on this one. You guys are great! I'm proud to be among you!
Cheers!
@ Diyers
What is the thread or posts about Diamond Buffer F6 version ?
I get pcb's set recently for future build. Thanks in advance :magnify:
@jdg123 welldone for Extreme working. Change the psu resistors with the hammond 159zj. I am sure that It will be better. And if you like to play with amp, add bypass caps on last psu caps. For example parallel 2.2uf+0.1uf . For just fun 😉
Hi, Newbe here, so sorry if this is a dumb question. I am thinking of building a F6 and would like to know if this box has adequate heat sinks on it's sides. It is available from E/B at a cost of $60 including postage, not a bad price
Full aluminum silver enclosure WA92 blank chassis/AMP box 213*70*245mm R16 | eBay
Also I hopefully cab use my DCB1, but wonder if I will have enough power to drive my 91db - 6ohm speakers. Cheers 😕😀
Powersupply might need to go in another case (not a lot of room)
Thanks, Good idea, If I put the Trans & P/S in a separate box, Would E/Bay box be OK😕
DIYaudio case + shipping to NZ much to expensive for the project.
That would be a great idea I believe. What type of connection type are you planning for psu case to amp case? I think XLR would be a good idea. In that scenario, I think some additional caps need to be placed inside power amp case across dc rails.
Sent from a handheld device. Some typos may creep in
