F6 Amplifier
Thanks Nelson
I did get inspired at Burning Amp
but credit goes to buzzforb !!!!
He did such a great job with the boards 😀😀
F6 heatsinks
Getting proper heat sinks for the F6 is a bit of a chore here in the north... How big should they be, compared to the F4 for an example? The F4 has 6 Jfets per side, the F6 two. Would the F6 do with less heet sink area? (I happen to have a F4 on loan right now so that's why the referece.)
- Jugi
- Jugi
Take one each of these per channel (200mm length):
http://www.fischerelektronik.de/web_fischer/en_GB/heatsinks/A01/Standard%20extruded%20heatsinks/PR/SK479_/$productCard/dimensionParameters/index.xhtml
Power supply question
Need some explaining I'm afraid...
In the power supply schematic, on the primary there is a thermistor(?) sign, but no value mentioned. Does the thermistor really exist and if so is it mandotory? And if it's manditory, or at least recomendable, does that mean that the primery shoud be splitable?
Thanks guys! These all seem like good alternatives. Have to do some calculating of the chassis and then decide. Hope the companies don't then have any minimum amount - other than 2 pcs of course.
I ordered the 2 heatsinks from Conrad heatsink but I was in no hurry so I went with shipping by boat so it took 2-3 month but was cheaper than shipping by plane.
Another question about that power supply... The Schematic of the power supply is clear now, but on the attached pic you can see some other parts too that aren't in the schematics. What is that 'tower' thing in the middle of the caps? What's it's function and? And also what are those three small caps on the board. Would they make the power supply better if included?
Hmm.. can't seem to get the picture attached - so here's the link.
http://www.6moons.com/audioreviews/firstwatt16/4.jpg
