F6 Amplifier
lhquam -
I love your schematic!
What input devices are you using? May I assume that you are cascoding in order to make more power, and have higher voltage rails than the "normal" +/-24V?
The input devices are "standard" 2sk170 and 2sj74 JFETs. My use of cascoding is to reduce higher order harmonic distortions due to the Early effect and device capacitances, not to increase power. Cascoding greatly reduces the negative effects of the gate-to-drain capacitances of the drive MOSFETs (those receiving inputs from the transformer secondaries), allowing the use of VFETs that ordinarily would not be considered. The power dissipation of the drive MOSFETs is low: set by the cascode voltage and the idle current. The cascode MOSFETs dissipate most of the class-A idle power. I am using FQA28N15 and FQA36P15 MOSFETS for both purposes. There might be good reasons to consider BJT devices for the cascodes.
You don't need the P-channel in an F6... 🙂 🙂 🙂
But yes, the P-channel compliment is the 12P20, which buzzforb also has lots of.
(I wholeheartedly recommend his Fets - they are genuine, matched, and very reasonably priced.)
