F6 Amplifier
Dont over think it. Build it and change the cap if it sounds bad. That being said, Vishay MKP1837 is well regarded, and i have not been able to distinguish it from WIMA MKs2 or Mundorf Zn(I think), when i tried interchanging them in a circuit.
Are your saying they will work good or better than OK?
You two are funny!
Burning up a bunch of space someone will have to dig through looking for quality information.
Oops, I just posted and provided no quality info again! Doh!
A little DC won't kill the performance, just limit the bandwidth. Effects bass by saturating the core.
Hope I saved the post,
Rush
LOL
naah
sometimes even I can't keep with my self :rofl:
what I meant is simple - when you achieve adequate working conditions for xformer - great one will work great , good ones will work good
but , when you have less than optimal setup , great ones will work good , while good ones will work mediocre
so - conclusion is simple - you need to put some (real ) time to achieve best workaround for xformer , where Spice can't help you much .
it's simple if you have enough mileage , and not so if you don't
for instance , I had opportunity to be advised that xformer can't be used for differential I/V conversion with two PCM1704 , especially with primary connected just to chips outputs ; luckily , I was enough ignorant to not obey local experts , invest some time in following my ignorant instincts ..... testing at least 15 different xformers ....
as Pa wrote - I just hook these things up and see what I get.
:rofl:
Compound Power Amplifiers
The Title [Compound Power Amplifiers] is an outgrowth of the intellectual stimulation and inspiration embodied in the F6 Amplifier thread. I started its own thread of the same title so as to keep the F6 Amplifier thread solely dedicated to it. DIYers have simulated, surmised, reflected, speculated, analysed, peacefully argued and chatted about simplified F6. Lucky Mr. Pass, he is already listening to an F6 [see What's New on www.firstwatt.com]. I show in the first post of the thread "Compound Power Amplifiers" a possible working model for simplified F6. It can be assembled, tweaked, auditioned and critiqued in a matter of hours.
looking at pic from #742 (attached )
in case B AC path for modulation is through C4 , which serve also as bias voltage blocking/maintaining/smoothing cap
in case A AC path for modulation is through C1 ; in that case C3 is just bias voltage blocking/maintaining/smoothing cap
Secondary loading alternatives
In the following drawing, methods B1, A1, and A2 show some alternatives for loading secondary winding and biasing the output FET. In all cases, Rsec is the secondary load resistance.
if you ask me - any of A derivatives
which one suits you most ......
I don't like caps in the signal path. They make me want to buy $100 each or more caps and worry why I was too cheap to buy Audionote $1000 silver foil caps. So my 1st preference is "B".
Then it occurred to me that sometimes we do things that make the output device exhale the smoke within. Does this trick of letting the smoke out ever short the gate to a rail and possibly burn out a winding on the secondary?
That would be bad, making me reconsider "A". But I don't know the likely hood of that. I have not let the smoke out yet.:Ouch:
Rush
there is no non-signal side
even in case of B1 case (post #774) , where you have proper loading resistor across secondary , value of C2 must be sized accordingly to wiper-lower end section of trimpot , calculated as bypass cap , or it will not serve prescribed duty
in that case - it's AC impedance is low , so trimpot value is of no importance , AC wise
conclusion - cap is in AC signal path ...... as it must be , because Jfet likes to see signal between S and G
:clown:
