F6 Amplifier
use 2 pairs of outputs , up PSU to +/-50V , keep static dissipation per device under 35W and :clown:
Please see the attached file for another possible option to boost power of the basic Conceptual F6 and its clones if needed. I am borrowing the established approach of the classic STASIS {R} technology invented by Mr. Pass. I am describing a powerful Class AB power amp with a potential Class A performance.
Both JFETs are operating in a highly linear state. The upper JFET and its bootstrap multiple PNPs are operating in true STASIS{R}. The JFET is a linear voltage source amp controlling a much more powerful transconductance amp [the PNPs operating in the common source configuration] which are on the verge of conduction in their idle state. In operation, this net combination is a powerful voltage source amp [and very low output Z] which does not need corrective loop feedback at all because the upper JFEt is close to being error free by design [the invention].
The lower JFET is also operating in a highly linear mode. It drives multiple NPNs [complementary to upper PNPs and also operating in the common source configuration. This arrangement is not STASIS{R} like the upper section; because the lower JFET is not complementary to the upper JFET. So the lower JFET does not correct for error introduced at the output node due the bootstrap NPNs. But,; note these two relevant connections:
  • The upper STASIS{R} section still monitors and corrects for error due the lower NPN bootstrap transconductance amp at the output node. The upper JFET does not know where any error [distortion] is coming from. If the upper JFET is designed to do a great job at error correction for both the upper and lower bootstrap BJTs, then no loop feedback will be required at all to get high power and low output Z simultaneously.
  • Still have the added option to practice loop feedback to do more error correction if needed.
The obvious, but not cheapest, way to get more power and lower THD is an F6-Balanced.
Take 2 "normal" F6 channels with balanced inputs In+ and In-, and connect the outputs Out+ and Out- to the speaker. Here is a simulation THD vs Frequency sweep:
May also consider driving 2 normal [whatever this means] F6 clones with a third Jensen; adjusting for the proper phase of the secondaries to get the +/- INputs.
