F5m kit
Question. The store has the Pesante 3U 300 without heatsinks. Where could I source the heatsinks for this project? I know that the PDF mentioned 40MM heatsinks. I saw this one at modushop.
Or would it be easier to just order a Dissipante 03/300B 3U 4mm SILVER
I also have a e-waste Chassis that is kind of the same size as a 3U but I am unsure if the heatsinks are big enough. I was planning on using it for another build.
Here are some pictures and dimensions.
Reactions: 6L6 and WBS
Jacruzer787,
Looking at images of the tape measure held against the chassis, it looks like the internal dimensions of your chassis is 11" deep vs ~12" deep (300 mm) for the Dissipante, and also less wide (11" vs ~14").
The heatsinks look like ~62mm with base, and the base looks around 7mm thick. This means that the fins are longer than the Dissipante heatsink - this is better as there is more surface area.
The height of the fins if ~5" will be ~127mm, so slightly taller than the Dissipante 3U.
So all in all, thermally this chassis looks to offer similar performance to that of the Dissipante 3u x 300 mm chassis, but the internals are slightly cramped.
Look at the dimensions of the power supply board and transformer, and see if you can fit everything inside that space you have.
Reactions: Vunce and e_fortier
Fitting the F5m PCBs to the heatsinks will not be a challenge - the PCBs look compact enough. 🙂
I was referring to the power supply board and the power transformer.
Some transformers are larger in size than others... specially the Antec units are on the bigger side.
The power supply PCB looks to be roughly 140 mm x 125 mm - maybe someone can confirm that.
P.S. Some power transformer choices (2 x 18V AC):
250VA unit - will this work with lower bias points? Or undersized?
https://www.parts-express.com/Avel-Y236651-250VA-18V18V-Toroidal-Transformer-122-620?quantity=1
Antec 300VA seems out of stock:
https://www.antekinc.com/as-3218-300va-18v-transformer/
Antec 400VA is in stock:
https://www.antekinc.com/as-4218-400va-18v-transformer/
Well built, but higher priced unit:
https://www.newark.com/block/rkd-300-2x18/xfmr-toroidal-300va-chassis-rohs/dp/78AK8186
Reactions: Jacruzer787
Since we are talking transformer options, I'll ask if the Antek AS-3220 would also work since the AS-3218 is currently OOS? Its probably already been mentioned somewhere already. I presume it's fine and the benefit is it's currently In stock for purchase. Just wanted to confirm.
Reactions: 6L6
