Hi everybody,
I have plan to build f5 v3 ,where can I get FQA 12p20 and FQA 19n20?
I used google and found this one and I saw other sites,Try this one! Supplier of FQA 1 Electronic Parts. Free Price Quotes
Have a good sounding DAY!
NS
Contact member "Buzzforb" or member " H_A "
Also understand that IRFP240/IRFP9240 will work perfectly in this circuit as well.
Hi everybody,
Hi you can order on line from RS Singapore.
Is it just me or can 18 awg wire be used with the F5T boards? Seems that I can only get 20 awg to fit.
If you are talking about the latest version F5T boards that the store is selling you are right in that the holes are ridiculously small. What re you building?
See my post #3528 under the F5 Turbo Builders Thread. I have also complained to the store about this issue and I suggest you do likewise.
Nash
But we should not need to cobble together a solution.
That's exactly the point!
Not when boards are produced for a specific application by DIY enthusiasts for DIY enthusiasts.
Nash
In a such a short cable into low powers, inside amp a single 20 awg is more than enough, in my opinion, and better sounding than big size multistranded common wires
Best
Yes certainly for the signal wire 24AWG or even thinner.
Nash
Best
True in most cases, however, these boards and the associated MOSFETS are capable of passing over 40A of current!
BTW the V2 ones that I have can accept 14ga solid core wire or 15.5ga stranded
This ought to be perfect:
Through hole pin digikey
http://ca.mouser.com/ProductDetail/Harwin/H9026-01/?qs=sGAEpiMZZMu6TJb8E8Cjr6e5DNTNKBA0
The ones from mouser do not fit. I assume the others won't either, being the same product number.
I decided to drill out the holes to a larger size. Sure you lose the thru hole plating but all the holes I drilled had the trace on one side only.
Nash
- F5 Turbo Circuit Boards
