Hi Scott.
I've had good experience with Kendeil caps .... some nice ones 63V 15000uf from umut1001 on ebay (on my ba3 monoblocks). He'll drop you 10% if shopping outside ebay.... worked well for me.....
I may have some for sale , but they are 50,000/ 50 V also from Umut ... Haven't decided on them yet ..
Hello.Somebody talking about me here thanks
I have very nice caps here.Limited quantity do not miss
http://www.diyaudio.com/forums/vend...5000uf-40v-caps-f5-turbo-amp.html#post2981744
Umut,
Tried contacting you a few times on Ebay, sent 2 messages , but you never responded ..
yes!!!!
A lot of the changes are so they work with the Universal Mounting Standard (UMS) so they can be bolted easily onto the heatsinks of the new chassis' that we'll have in the store or into a chassis that you already have drilled for a previous PCB from the store.
But in the process, I think they've become a lot more versatile too. Allowing a lot more Turbo options!
Mark
Mark
Speaking of the heatsinks for the proposed chassis, please find attached PDF showing the current placement of the holes relative to the top and bottom of the heatsink itself. It would be great to have some feedback from those knowledgeable in the field as to whether our approximations of how much lower to place the holes than the center line to compensate for the top of the heatsink getting hotter than the bottom are spot.
Jojo
Jojo
Jojo
2/3 from the top has worked fine for me.
Gentlemen,
Just to let you know, I've been working on a redesign of the boards with Variac that meet diyAudio's USM.
The mounting holes for the input stage and PSU have been modified to match the perforated bottom plate of the pre-drilled case that will be available.
In addition, the PSU now has large screw terminals and accomodates 40mm & 45mm snap-in capacitors.
The Input stage is a single board with a score line for SE and a jumper link for balanced.
Images are posted below.
Power Supply
Input Stage
P Channel O/P Board
N Channel O/P Board
Power Supply
Input Stage
P Channel O/P Board
N Channel O/P Board
My sinks don't have as large of a wing profile as the one's here, but 2" (~50mm) and one for each diode. It is only a concern. I cannot say with any certainty that it will become a problem. If the beta-testers could tell us about the sink temp under load - that would be most helpful.
I think it's a good bet that any F5T will need to be in a chassis that is not only adequately heatsinked, but a well-ventilated inner case as well.
Or, we could always just use the 200V 35A bridges that have been the staple of the "Pass/Zen/Firstwatt Vernacular" style of PSU. They work.
That said, I really want to see the PSU be easily usable as designed.
- F5 Turbo Circuit Boards
