ZM. a question. i have pr now R5/6 at 1Kohm, and 7.1mA J-fets(i forgot to calculate a reise of the resistance)
i can solder in some 2.2Kohm resistors. or i have another set of 7.1mA J-fets i can solder in, to dobble up the J-fets. what would you do? i don't know if 2.2K will be enough for 7.1mA fets. but with dual 7.1mA fets, 1Kohm chould be enough? right?
Audiosan or ZM , could you please explain this? Wouldn't the cascode take care of it already and not require more? I'm going to be building a 4pr w 50V rails should I have more than one pair of jfets?
What am I missing?
the cascoding takes care of the voltage the J-fets get. but the J-fets need to drive the the output fets, that demands some current. you can drive 4 output pairs with a single pair of J-fets. but it may be a little more narrow bandwith. you may also need to up the resistance for R5/6 to reach any bias current for the outputs.
I had no problems in driving 4 pairs of outputs with a single pair of J-Fets in a cascoded mode and also did not require any change in resistances. I did two channels in a large enclosure with natural cooling but could not sustain it. Have now resorted to forced air cooling and the amp works fine at 375mV bias on each source resistor.
anilva,
Since you have active F5, F5TV2, and F5TV3. Perhaps you would like to comment on the differences.
If I'm not mistaken the Toshiba 2SK170 and 2SJ74 both have Ig = +/-10mA.
Would this then be ok with 4pr without deviating from Pass's schematic?
Thanks Anilva, I take it you're using the toshiba's as well?
Yes also what are you impressions of all 3 F5 variants?
anilva,
Yes, I am using the Toshiba JFETS at 10mA IDSS.
As fas listening impressions are concerned, I have written elsewhere as well, but I will repeat again. The F5 has absolutely high resolution and very clean sound with tad weakness on the bass.
The V2 comes across lot more powerful and controlled and with tight bass but at the same time has very F5 nature of sound in term high resolution and detail.
The V3 takes it further in terms of more headroom and dynamics with very controlled performance across the spectrum particularly bass and ofcourse the classic F5 resolution.
Mind you, I have not tweaked P3 in any of these setups and is at midpoint. May be the character will change if tweaked. I also have a dual output Toshiba F5 which has slightly different but warmer character than the standard F5, but definitely not as powerful as V2 or V3.
My listening tests are done with a full range back loaded horn based on fostex FE206 and with another setup consisting of active altec 515 LF and Altec 288K HF with a Le'Cleach horn.
Hope this helps. YMMV.
Cheers.
It depends on their grade.
GR = +/-2.6 to +/-6.5mA
BL = +/-6.0 to +/-12mA
V = +/-10 to +/-20mA
Ron
I have my fingers crossed that someone will come through with an F5Tv2 in a 5U chassis from the store as a dual channel amp. I know that at least someone has thought about that setup.. it must be..
That's my plan, unless funding forces me to build one like my first F-5 build. Variac said this case (5U) would be perfect for this project, (V2), or 2 4U cases for monoblocks.
Russellc
I'm hoping to have a dedicated 30KW solar array and deep-cycle battery storage system dedicated to my audio system.
To listen to headphones. 🙂 😀 🙂 😀 🙂 😀
Back on topic...
I hope to be getting my PCB and heatsinks in the next few days!
Alright, and great idea! Taking class A Green!
Russellc
I'm afraid they will put me on a no-fly / terror suspect list by the FBI if I buy those kinds of heavy duty caps! You know how we love our conspiracy theories in this country.
My take away is that I need to go shopping for caps!! 😱
Just to be safe, when you "fire it up" use a variac................slooooowly. Or the lightbulb in series trick.
One of the two will come along and correct me if I was wrong.
I need to make a decision about how wide to make this thing. I would like it to be as narrow as possible as the sinks are four inches wide. How much room do I need for the ps?
I think about 10" is minimum. Its what I have and things feel tight. What is your overall length. You have to 6" plus for toroid. Mine is 18" deep/long and 10" wide.Next will be bigger.
- F5 Turbo Builders Thread
