Thanks Buzz.Would there be any benefit to cascoding or is it a waste of components at +- 35v dc?
Cascade keeps Jfet drain at ideal V, reduces mr miller, as well as dissipation. In theory, it should always be better. OTOH, it adds another junction. At35v, all that is moot, as I think it is necessary, because you are really pushing dissipation maximums.
try your calculation on the F5 and see if you get 64W dissipation pr ch. (thats the correct number for a F5) and the F5 run on a single 300VA transformer.
AudioSan,
From the F5 manual:
"For this sort of circuit, a 1.3 amp bias means that the amplifier will operate Class A to 2.6 amps of output current. To understand this, imagine a condition where Q3 and Q4 are
idling at 1.3 amps, so that all the current is going from the V+ voltage rail to the V- voltage rail, and none is going through the loudspeaker."
I read that as 2.6 amps (the total bias through all devices) from V+ to V-. That's also the calculation in AndrewT's post.
Are we both incorrect? The numbers agree perfectly with transformer VA = 6-10 Wrms -- actually perfect at 8 x Wrms.
I will try them tonight, and repost all the formulas I used -- it looks like I have an error in one -- the number in the post does not agree witht the formula for VAbias.
Thanks for confirming what I was thinking.Do I stick with two pairs of outputs and bias high or try four and bias lower.I guess its try both and see which I prefer.
keep bias at around 0.9A pr device. over that and you risk that diodes starts cunducting within bias. if you want higher bias, then you can add more outputs or lower the source resistor values.
When Buzz finishes his 8pr version , we will be shown the way ...🙂
Ha! Actually ave a decent excuse today. In NewJersey.
Try v2. Stepping is no problem, but will require bigger PSU and toroid. More pairs means more total Yfs and DF. Also lower bandwidth. Really unnecessary unless you need the power. Main reason I am building up stereo versionis to see if Wayne is right and more equals better sound.
8 pair? that is just insane 🙂 i hope there is dual input pairs too 🙂
Whatever it takes , thinking of seperate supplies ala XA -series, even dutchie would be impressed ....
OK, I'm *very* confused.
I can't understand a whole bunch of AndrewT's post. So, I go back to the F5 manual, and try to turn all the pairs into a single pair.
When I look at the F5 manual, I can see where the 62 watt dissipation per channel comes from:
One pair of devices, Rails are +/-24 volts, the Ib = 1.3 per device.
That's either (2 x 1.3A) x 24 or (1.3 X 48) = 62 watts
Two channels gives you 124 VAbias. Sizing the transfomer for twice that gives you 248 VA. A 300 VA is more than enough transformer.
Output power I^2 * R = 2.6 * 2.6 * 8 = 54 Wpeak = 27 Wrms.
Let's change the bias a little.
One pair of devices, Rails are +/-24 volts, the Ib = 1.5 per device. 3 amp total.
That's either (2 x 1.5A) x 24 or (1.5 X 48) = 72
Two channels gives you 144 VAbias. Sizing the transfomer for twice that gives you 288 VA. A 300 VA is still enough transformer.
Class A Output power I^2 * R = 3 * 3 * 8 = 72 Wpeak = 36 Wrms.
Try 2 pairs of devices, 3 Amp total and 50 volt rails. Ib = 0.75 A per device.
If this was one pair, it would be 1.5 amp each device.
Class A Output power: ( 3 * 3 * 8) = 72 Wpeak = 36 Wrms.
NOTICE THAT THE CLASS A OUTPUT POWER DOES NOT CHANGE, since it is biased to the same current.
Sizing the transformer: That's either (2 x 1.5 A) x 50 or (1.5 X 100) = 150 VA. Double that for 300 VA. Two channels is 600 va.
4 pairs ( 8 devices ) 6 amp total ( 0.75 amps/device). If it was one pair, it would be 3 amps/device.
Class A output power: ( 6 * 6 * 8 ) = 288 Wpeak = 144 Wrms.
Sizing the transformer: That's either (2 x 3 A) x 50 = 3 x 100 = 300 VA. Double that for 600 VA. Two channels is 1.2 Kva.
Are these numbers reasonable?
A toroid that is 3 to 5 times the dissipation amount is the best way to calculate things. Bigger is almost always better in this case. For exact theory, look on ESP site.
BigE said:A 300 VA is more than enough transformer.
For a standard F5? Yes, certainly. It's what Nelson uses in the factory built ones.
Definitely got to go balanced at that point.
Not where I'm going...... 🙂
bigE those numbers are correct. exept for the last one. the rail voltage is to low to reach 144W at 8ohm. same for number 2🙂 and as buzzbord said. transformer rating of 3times dissipation is a good way to go. 2 times is minimum. i like 3 times. that gives you more headroom and lower temp in the transformer. but when a transformer reach a certain size, then bigger is not allways better🙂
- F5 Turbo Builders Thread
