F5 Turbo Builders Thread
and it is no way to adjust P1 and 2 to get some readings over source resistors? it is over them you want that 400+mV
I twiddled some knobs, and got some voltage across them 🙂
Problem is I'm at the limit of the pots and have 150mV across the n-ch source resistors and 145mV across the p-ch
I remeber in the stock F5 thread some people had to add an extra resitor to get more range out of their pots...
I'm using IRF parts if that makes a difference.
I've done a search, read quite a few posts but have not quite seen this question addressed.
Is there any advantage to using 3 pairs of Mosfet output devices per channel rather than the standard 2 Pair when building a V2? w/32V rails.
Less bias per device = cooler sinks? Tea-Bag eluded to this in his earlier post.
Sonics better or worse?
Hi Guys,
I got these in the mail yesterday and have been at them mostly since,
Check them over,
I am planing on 32 volt rails,around 15 volts for cascode,
I couldn't find the link about the link,Link to gnd?
Q5 and Q6 are correct with the silk ,are they backwards ?need to be turned around?
N out and P out switched on signal board,
any known issues?
I decide it was best to ask instead of smoking,,,,,,,,,😱😱😱
Thanks alot,
NoSmoking.........😀
Hi Guys,
Check them over,
any known issues?
Thanks alot,
NoSmoking.........😀
Power up FE first and set drop across r5,r6 to 3.5V using P1 and P2. THis will allow you to figure out which way to turn the posts in order to adjust them. You will be starting at similar Vgs and will have solid footing for hooking up mosfets and firing them up.
Q5/Q6 is correct oriented on those boards. N-ch and P-ch is also correct.
Hi Guys,
Check them over,
any known issues?
Thanks alot,
NoSmoking.........😀
