F5 power amplifier
Patrick might be able to help Audioholik with his voltage question. I believe his F5 is running 16V rails.?.
Of course he is running his own balanced version but might have some good input.
Also, looks like Fredlock is getting 22V rails http://www.diyaudio.com/forums/showthread.php?postid=1565412#post1565412
And I went back but didnt see any Zen schematics. Must have been in the B1 thread.
Uriah
Attached is what I deem to be corrections regarding the fets that where pointed out. Maybe someone could just double check...
The F5 kitsch amp runs on CRCs with 2 x 10kuF per rail.
A classic average PS lytic number for PP Class A power amps is 1000uF per continuous watt (8 Ohm, per channel)
The F5 PSRR isn't shattering, 40kuF/ch for 27W/8 average is a 50% higher value, plus the advantage of the additional CRC filtering.
