F5 power amplifier
Select the jFETs by Idss as recommended. That's all you have to do.
Well, not quite.
I would accurately measure all the resistors and select to ~0.1%, both between upper and lower and between channels.
This makes for reliable current measuring later, if there are problems to be corrected.
Hello,
I've not been able to find or to understand an explanation to the need of matching transistors in the original F5 amplifier.
Within a single channel, I "extrapolate" from various diyaudio threads that P and N MOSFETs don't need to be matched (also because they are technically different). But what about the JFETs?
I also "extrapolate" that matching MOSFETs and JFETs between left and right channel is not necessary (probably it's useful if I want to do the same operations to bias the two channels, but I'm not sure about it).
Any help is really appreciated 🙂
To operate, there is really no requirement that the parts be matched. I like them all matched, simply because I want both channels to match as close as possible. It just depends on how obsessive you want to be....
russellc
Well I don't think so, I know for sure !!
I think, with a little luck... the F5-T will be released this week 😀
Jesper.
When it's ready, Choky (Zen Mod) and I will get it from Choky's Papa (Mr. Pass) and we'll build and test it within a few hours and after that it'll be presented to you all 😀
Just hold on there and you'll be rewarded with the fantastic turbo sound for DIYérs :rofl::rofl::rofl::Pinoc:
Audiofanatic 😉
naah ....... I'm forbidden to mess with turbo
last time when I had it , I won Pike's Peak 3 times in one day
