F5 Headamp ?
The circuit has quite good PSRR. So the power supply is not so critical.
But Stixx spent some time trying different ones out and preferred the cap multipliers.
Maybe he could give you more details.
I just used the 317_337 CM's as they are simple and have no stability issues, being open loop followers.
Patrick
+12:45 UTC actually (3/4 of 60 =45) 😉
https://en.wikipedia.org/wiki/UTC+12:45
Happy New Year!
+12hrs would be for New Zealand and many others
That would equate to 1200hrs GMT.
But Chatham Islands is 12¾ hours ahead and that would be 45 minutes ahead of 1200hrs GMT.
That would be 1115hrs GMT.
Or, have I got that wrong?
My point was that I did not know anywhere was 12¾hours ahead.
I had thought the limits were 12hours behind to 12hours ahead of GMT.
And on expanding the map to full size I see that Tonga is @ +13hrs and Line Islands is @ +14hrs.
For clarity here is a list of the layout errors in Version 1 :
1) The supply lines for the 9V regulator for the LDR CCS need to be swapped. Easy to fix even if using LDR.
2) The current limiter has a layout error in the BJT pin assignment. Cannot be fixed. We don't use the limiter.
3) The case connection to earth needs solder resist to be scrapped off. Easy to fix.
4) The mounting hole for the LDR CCS (pointing downwards) is missing. Easy to fix even if using LDR.
Patrick
Having a V1 board, I confirm it's very easy to fix. What needs to be aware is that the boards (especially the cap multiplier board, if that's gonna be part of the package) are having quite some 0805 size SMD parts. I soldered a few of them, and I decided I need to first buy a magnifier with light before continuing.
But then, it's gonna be the same either V1 or V2 🙄
Only very brave young man will dare to solder 0805 without magnifying glass, and without practice.
But I can tell you that after some persuasion and then some practice, even a 60+ year-old DIY prominent figure can also handle 0603 LEDs.
And I strongly recommend you use a hot iron (420°C) with a very sharp tip.
And 0.35mm solder, preferably leaded or low melting temperature.
You definitely want to use lower temperature when you solder SMD PPS caps (not in F5-HA).
Patrick
Patrick,
Thanks for making these boards available, I am interested in one V1 PCB for the F5HA. I have been watching this and the DAO follower and plan to eventually build both. 🙂
Please PM at your convenience for cost and shipping details
Adam
