F4 power amplifier
Thanks ZM for pointing out the error. I took the writing from the F5 board to make sure it looked the same. Should be corrected here. 😱
Hi choky,
didn´t you only try this with your "last last F4":
"If you have a source which can drive 5 Kohm and a couple hundred pF,
you can dispense with the JFETs altogether and simply drive the Gates
of the Mosfets."
A little more work, and you can use a single pair of Mosfets and raise
the impedances of the bias circuit, and then it would be about 22K and 70 pF."
post #2913 from Nelson Pass
