F4 power amplifier
This is what i had in mind :
You see here one side of the chassis, the sinks will be bolted together ofcause.
Jesper
ROVSING said:
I have seen something like those heatzinks before, used fore windmill purpose - any windmills standing still in your area ?
I usually cut them down like timber😀 I think I saw some of those heatsinks somewhere😎 Nice they are, but they wont hold the 40 output devices required for the AX.5 I think:dead:
Can you get a larger baseplate and bolt all the fets onto that plate for thermal coupling instead - you'll get a larger dissipating area as well
HHHHHH HHHHHH
_HHHH___HHHH_
..FET........FET....
Sort of like that (if you can make out my crappy drawing)
HHHHHH HHHHHH
_HHHH___HHHH_
That is actually a really cool idea Twitchie😎 That would also make it possible to do 4 channels in one chassis! Those heatsinks can dissipate the heat, dont worry.
Steen🙂
cviller said:
I doubt it... but if some day you see someone climb one of those windmills with a screwdriver, it might be me! :devilr:
Mount your amplifier on the top of the windmill instead - alternative fancooling - we have to think about our environment, yuo might have to make the connectionwires a little longer
HeHe don't bother as long as the signal is balanced... 😀 Might be a good idea!
I would like a little more explanation about the
HHHHHH HHHHHH
_HHHH___HHHH_
Is is supposed to be seen from above ?... looks like a good idea, but i don't get the hole idea through ?
Jesper :hot:
