hi Zen
checked it out ,looks nice but I was hoping to do something without a transformer
I,m thinking ba3 front into f4 using 2 pair 2sk82/ssj28 per side
I read somewhere nelson said "they make great followers"
and I already have 2x fully populated f4 boards to try
any advice , on whats involved dropping these in
Sheafer
Sheafer
it deserves dedicated thread ......... biasing ( depletion mode parts ) is what's most complicated
however , when made properly , you'll not hear so easily difference between boutique parts and plain vanilla mosfets based follower stage
so , if name of the game is fun - why not ....... but if you expect some miracle , it's just throwing money and time through window
Sheafer -
I agree with ZM; using unobtanium rare parts in a follower is gilding the lily. One of the (many) reasons to use a follower stage is that the devices themselves impart very little of their sonic character on the signal. You will get as good results with more commonly available parts.
You want an amp where the signal makes it through the output - an F6-style would be fantastic in this regard, and be a good place for your parts.
If you have the F4 PCB, build a 'normal' F4... It's a fantastic amp in it's own regard.
ok guys
get the message ,my problem is I,ve stuffed up one of my f6 boards (lifted traces) from trying to repair a mistake I made and would have to buy new boards to make it work
I spose I will just concentrate on the f4 for now and put the sony parts off for another day
I have
cheers Sheafer
I have
cheers Sheafer
Fine....!
Francesco was already active here as mos57, Look here
http://www.diyaudio.com/forums/pass-labs/216616-f6-amplifier-500.html#post3567209
So I think he will not mind making boards for the circuits he posted here at diyaudio.
hi guys
we have approval from Francesco
I will start a dedicated thread in solid state ,all welcome
hi Buzz
I may still try the f6 variant but I am hoping to try something without a transformer front end to start with as I just want to hear the sony parts "sound " first with out other flavours added
regards Sheafer
hi Buzz
regards Sheafer
Is there any consensus about the choice of MOSFETs in the F4? I have the following to choose between:
FQA28N15/FQA36P15
IRFP240/IRFP9240
FQP19N20C/FQP12P20
FQP16N25/FQP17P10
I suppose I could give them all a try, but I was hoping for some comment on experiences others have had.
FQA28N15/FQA36P15
IRFP240/IRFP9240
FQP19N20C/FQP12P20
FQP16N25/FQP17P10
I see the Fairchild 19N and 12P parts are much cheaper a 1/3 of the price of the IRFP parts.
As I have not bought yet.....what should I buy? Why did you use the Fairchild parts 6L6?
So you have good luck... they are unobtainable normally...
the 19N and 12P haver a brighter and more detailed sound, but of course less relaxed than the IRF, matter of taste....and speakers and room .... and CD-player.....and .... and ....
- F4 power amplifier
