samsagaz said:wow these caps are expensive :S
will get sound improvment using that kind of "expensive" caps? :!
I bought the Jensens mostly out of curiosity. You don't need to use such expensive caps to get the sound right.
Regarding "normally" priced components, my first choice would probably be Nichicon KG Super Through or Gold Tune 15,000/50 available from Percy, 10,000uF should work fine too.
As to Sikorels, I bouth those at local surplus outlet, years ago.
Peter Daniel said:BTW, I'm using Nichicons in F3 and the amp came out very well.
I like Caddocks MK132 at input shunt and feedback.
One more question abt caps, wich are BG cap that are used sometimes in the input path?
chrismercurio said:Which R(x) positions qualify as input shunt and feedback loop?
For which amp?
Peter Daniel said:
For which amp?
The F5. I'm looking to put together a BOM for ordering from in the next week while I work on my universal Fx supply that can run 2 F amplifiers.
Best,
Chris
themystical said:Anybody have a couple of LU1014's in the UK for my F3 Build?
You can find them here: http://www.audioprojekte.de/html/halbleiter.html
Peter Daniel said:Those would be BG N, either 4.7/50 or 10/50
Excuse my ignorance, but is this cap placed between the input and ground, or does this go into the C9 position on the PCB?
I was normally using laser print paper, but for some mailings the weight and thickness was critical that's why the "funny" paper choice
That was a general question, not neccessarily related to any of the F Amps:
rhing said:Excuse my ignorance, but is this cap placed between the input and ground, or does this go into the C9 position on the PCB?
samsagaz said:One more question abt caps, wich are BG cap that are used sometimes in the input path?
for F4 input shunt is R2 and feedback would be R24 and R25? am I right ?
Peter Daniel said:That was a general question, not neccessarily related to any of the F Amps:
Thanks for the clarification, and thanks for sharing your experience with the power supply caps.
Current Limiting thermistor
Dear Peter or whoever has an opinion,
Are you using this in your amps?
Mr Pass suggests a CL60 thermistor to be placed in the primary of the power transformer.
I have know nothing about thermistors, other than what they do, so what is a CL60 thermistor?
Do you recommend these be used and if so would you recommend a part number, please.
Thanks,
Thanks,
- Group Buys
- F3 and F4 Clone PCB Reissue group buy, also F5 PCBs
