Explendid amplifier designed by Michael Bittner, our MikeB
Thanks,
With that info, should be a breeze. I'll try it. May also try the GEM amp. Dang, I never shoulda looked at the SS forum, but Carlos's enthusiam sucked me in. That, and waiting for speaker parts has got me making amps in multiple numbers.
Sheldon
Mike,
yesterday evening I replanned Your amplifier, little bit. The input stage use PNP devices, with 2mA bias. The VAS use BD139/140 transistors, with 8mA bias. I keep the 68ohms as common emitter resistor, but I applied 82ohm local feedback in the VAS. I changed the bias network, to get better thermal compensation. So, now I working on the PCB design...
sajti
Hi Sajti !
So, a complete redesign ? Can you show/send me schematic ?
With that much changes it will be necessary to readjust
feedbackcompensation. The thermal compensation worked "perfect",
for doubledarlington a simple vbe-multiplier does a very good job.
Just a hint, high current in the inputstage is not necessarily a good
thing, a lower current here in combination with lowgain-bjts in
the vas can improve quality as you get more a currenttransfer
from 1st stage to 2nd stage instead of voltagetransfer. (In theory)
Don't want to give a chance to my version ?
Mike
Sheldon, i really apreciate this amplifier, Satji, i have something to say to you.
Symassym
Aksa 55 with nirvana upgrade
GEM Diamond...(the last published)
GEM 25W
JLH 1969 and DOZ
I construct 3.7K amplifiers...when i stop to count them... observe that no one in the list i wrote above are industrial amplifiers, as those i only apreciate an old enormous tube Mac Intosh amplifier.
Those ones i wrote above I like, all them, very much, and they were not written in my preference sequence.
I did not answered you Sheldon, because i left space for Michael enter, as he is tracking the thread, in the reality, i introduced, but the thread belong to him, he is the designer.
Satji:
I really made Michael amplifier with BD139, but was one of his first designs, and did not worked that first one, and i am sure was my construction failures, as Michael constructed and the unit worked....but was not aproved by him, he perceived harshing distortions in the treble range.
As a result, i avoid to use those BD139...but i jumped to his brother, the BC639 and BC640, and those ones have the same silicon die inside... but beeing a very small transistor, can only dissipate 1 watt, and cannot accept more than 1 ampere.
But those ones, alike the BD139, have not wonderfull gain, have to select, and was hard to find units with gain around 150.
As Michael said, i really constructed with BD139...as BC639 is the same transistor...but i had problems inverting leads....this transistor have strange pins.... watching the label, with the leads pointing to the floor, from left to rigth, Base, Colector and Emitter.... the same as BD139...but, with the label facing you.... if you read BD139 with the label facing you, will result wrong, will be emitter, colector and base....and this confuses me.... i am having some agging effects, as i could perceive.
I have constructed 4 Symassym, and more 2 boards are ready to construct it very small, 2 inches by 2 inches...but i am very lazy to start....but when started i will never stop untill the unit is ready to run or to receive a 12 gauge shot!
To Sheldon or Sunrise, as someone asked some about that.
Thank you Sheldon, because of the enthusiasm you said that i have.
- The gain i use to say, and i imagine the same Mike are talking about is the DC gain. I use my digital multimeters to measure this...but you can assemble something to measure too.... with batteries and resistors you calculate 1 miliampere flowing into the base to emitter current, and them measure the current that will flow into the colector to emitter circuit.... divide the second by the first and you will have the DC gain.
- To big transistors, use more current to base...let's say... 20 miliamps...and do the same measurement.
- I think Rodd Elliot, in ESP pages, explain how to do that better than i can explain.
- This amplifier, Symassym4, had 3 milivolts off set measured.... was hard to measure, it is a hell stable and reproduce with a very impressive dinamics.
regards,
Carlos
MikeB said:
Hi Sajti !
Mike
Hi Mike,
I never make copy from any amplifier. I like to change them to my taste. I use more local feedbacks, intstead of the large open loop gain, and overall feedback. This method means less compensation, even it works without any compensation, if the overall feedback is low.
I will plan some different compensation possibility to the PCB, to optimize the final result.
I don't really understand Your comment regarding the current/voltagetransfer. 😕
I use smaller emitter resistors for the output transistors. (0.1R) I need more temperature compensation with them...
Anyother issue: I planned two pairs of output devices, to handle more output current, or even class A working.
I will post my schematic, after I count all the values!
sajti
Hi sajti, my early prototype also used 0.1ohm, it showed the same
thermal stability. This voltage/current-transfer is something i am
still rasearching, i have not really understood it...
But this is something that has big impact on sounding.
These caps in vas to gnd in my schematic, the do not only serve
as feedbackcompensation, they have 2 additional functions:
- add a constant phaseshift to reduce dynamic phasehifts,
that might be the reason for the great soundstage.
- lower zout of vas for higher freqs, in sims these caps lower
thd at 20khz.
Sajti, should a bypassed electrolyt not be sufficient ?
A asymetrical inputstage without inputcoupling, is this a good idea ?
Mike
Carlos,
thanks for the comments! I used BD139/140 many times in my amplifiers, and I never had any problem with them. The 8mA/40V is bit too high dissipation for BC639/640. Maybe they can handle it, but I'm not 100% sure, so I don't want to take the risk to smoke my loudspeakers :hot:
For BD139/140: I want to screw them together, to keep the temperature, as close as possible. It's much easier, than with BCs...
But of course the listening test will do the final decision.
Thanks for the notes regarding the pins!
sajti
thd at 20khz.
Mike
Thanks for the comments! I just add one more transistor to the bias network. It it too much, I just apply jumper on the PCB to forget it.
Interesting, what You told about the I/V transfer. Maybe I will try to make some test with the sound of the different bias on the input stage. I use 2mA long time ago, and it has good sound to me. I use some more series collector resistors as well. It results lower dissipation for the input devices, and gives better sound, but I don't know how.
I saw Your compensations, and I understand the 330pF capacitors halps to reduce the output impedance. I will use smaller resistors over there. And due I not use any simulation, I will set this calacitors with measuring the real amplifier.
sajti
Hi Mike,
typically the same devices with a different ß (like BC546A and BC546B) have a higher early voltage when choosing low-ß types. This means that the output resistance of low-ß transistors is higher. Higher output resistance results in higher open-loop gain. In this way using low-ß transistors for cascoding or VAS stage have some advantages. Or selecting types for a high output resistance/high early voltage.
All rigth Satji, as you intend to increase the current...better to use those BDs.
Keep us informed, this will be a fun to us.
If you can, send us pictures too...yeah!... we know the first prototype will not be too much pretty, but the assemble solutions are very different from one guy related the other.... i think those normal, relaxed, prototype works are very interesting.
The others, with wonderfull boards, with silk screen, they appear to be the same...or almost the same.
Those "spiders" constructions are different, each one of us with our own tricks and spatial solutions.
regards,
Carlos
dinamics is astounding
Carlos, below is the input voltage for the first and the second stages of symasim5 at 870 mV(peak) input voltage, when output just prior clipping point.
You can calculate very fast what amount of distortion will be generated in the second stage at 20kHz with 100mV p-p input signal.
This sound stage you are babbled about is accentuation of transients by intermodulation products…
Sorry
I am a blind version of Michael when i see those graphics
But Michael can understand your meaning, if you explain with more details... i think he is interested, his language is direct Dimitri, and sometimes it seems that he is saying something alike
- How deer you tell me that?..... What you mean about?... too much objective, short form, abreviation, ...the guy is German.
- I am sure he is crazy to understand what you mean with your graphics.... distortion is high, but more details related the way you measure, the schematic used, were you pick the signal, the details of the analisis variables used, frequency used.... a little bit more details...maybe i will capture too Dimitri....
Well...life is lonely to you.
Michael:
I could see Dimitri's Curriculum Vitae!!!... the man is a "monster" related know how.
I am blind for those graphics.
Thanks Dimitri
Carlos
Feedback Caps
I'm interested in trying out the symasym5, but don't have any 22p caps (well I do, but only ceramics). I do have some 27pf mica caps though. Any comments on using 27pf, and maybe changing the feedback resistors to 18K and 470 ohm? - I think that this would give slightly less gain, but that's OK as I will be using a pre-amp.
Thanks,
Hans.
Hi hans,
i suggest you take the ceramic 22pf, and if you like the amp you could
replace caps afterwards with micas. These micas improve things,
but do not mutate the amp.
You shouldn't change the feedbacknetwork, this is the most critical
part in finetuning as you would change feedback-ratio.
If you do change to 18k, you must also change the 22k at input
to 18k, or you will get DC-offset.
I made all changes possible there, also with bigger caps changes.
The amplifier always sounded good..... was very reasonable even using TIP3055 and TIP2955 over 8 ohms speakers
This amplifier, if distorts, have wonderfull and nice distortions.
It is very tollerant to changes...and can work nice with and without the output coil, with miller and without miller...could use it without RC used in Symassym4, the one is between colectors.
I am talking about Symassym4...the last model, i cannot speak a word about it.... as i did not constructed, and will not...as this Symassym4 is already very good.
The floating resistor, with charge suck out, the 33 ohms are critical, as changes there create problems with output bias...it can turn too advanced, having very big VBE and bigger current to output.
If this amplifier, produce 1 percent distortion, i will be constructing, only, the ones that distort 1 percent or more...as sounded very, very, very good... i will be sending "standards" and conventions to Jupiter...with one way ticket.
JLH, our prefered amplifier, the one half forum respect, have enormous distortions too...so...distortion may be not this monster we use to think....and considering that speaker will distort much more, the amplifier distortions will be not perceived.
regards,
Carlos
