How about the caps and resistors is it necessary or not....I heard that you don't use it....am I right...?
Soldering tssop....hmmm newer done it before....😕
I removed the opamps,caps and resistors because I wanted to use the outputs of PCM1798 directly to transformers. The "stock" adaptor will give you the sound of the OPA2604 installed.
I've got my DAC up for sale in the Swap meet section with UTC A-20's if anyone here is interested. Not sure if this is ok but if it isn't I guess a moderator will remove it...🙂
and how does the pcm1798 sound in comparison to the cs 4398? is it just different or actually "better"?
greetings,
chris
greetings,
chris
I have an idea for doing this without a scope...using a vario transformer and a voltmeter...
Connect a load to secondary and the voltmeter and the vario to primary. Turn op voltage on vario until the secondary no longer follows (saturation). You can check by moving voltmeter also...
Will that work?
Question: What will a magnitized core sound like? And why do the degauss from both primary and secondary? Is is the same core and ac??
Any comments to this??
greetings,
chris
Check my post #2129
Hello Pierre,Hi guys,
... It needs a little "clean-up" before wiring the trafos so I removed the two opamps under the board and all the parts in the signal path: resistors and Vima caps. After I put one 100R linked to the ground at each output and finally wired the outputs to the 50 Ohms taps of transformers.
Worth the try.
Pierre G.
Would you happen to have some decent before/after pics of this "bypass operation"?
My pcm1793 arrived today but when I plug it in it shorts the -12 rail 🙁
Any thoughts?
Also anyone got any info on some marinair t1460 transformers I've got pin outs etc?
Thanks guys
Any thoughts?
Thanks guys
Any thoughts?
Thanks guys
From where do you buy the PCM1793 or PCM1794....??????
Any pictures of this module/chip?
Hello Pierre,
When I'll have the time, I'll take some pictures.
Hi Raiatea,
I connected an headphone to the RCA jacks with an adapter.
It works but the output level is low, it apparently needs a preamplifier.
Thank you for the answer.
I'm wondering if it would be ok to connect a balanced headphone directly to the CS4398 output, via a transformer 1:2.
I don't know yet what the impedance issues would be (HD600 at 300ohms).
Also how would I control the volume ?
Will that work?
When I understand your procedure correctly, I should work. But be carefully, not to overload/overheat your trannie (I would also control the AC voltage on the input side to be sure).
Personally I prefer for safety a power amplifier as source. The scope can be replaced by the voltmeter safely.
Important is the very slow reducing of the voltage to zero after you reach saturation.
How a magnetized core will sound like?
Simply more distorted.
Why doing it from both sides?
Because you want to bring the magnetic particles in a chaotic order. Doing the procedure several times and from both sides eases this.
Franz
Hi I bought my chip from Lawrence @ eBay UK Shop - Law's Audio: DIAPHRAGM, AC ADAPTER, DAC
Although there seems to be something up with my subboard he is very kindly sending me a replacement without any hassel at all. If you contact him he will be most helpful I'm sure I paid $35 delivered to the uk
Franz
Thank you for your reply 🙂
My transformers are no-name, with 150Ohm DC on both primary and secondary side and 1:1 ratio. At what voltage level would you expect the saturation to take place? I will use 50Hz, and I load the primary with 47K, but I think it might be better to use a lower load for this proces? Perhaps 270R?
I dont know.
Why don't you download a free scope SW to be on the safe side?
Franz
Something different:
I tried the USB-input for the DAC and only one channel is working.
The other one sometimes gives some cracks and for 1 second some music.
Is this the USB-inputreceiver or the USB-codec in the PC?
Back to SPDIF no problem...😕
First thing to do is to try with another computer.
Yes, I just tried a laptop, same problem.
So what's wrong with this Dac?
So the problem could be around the pcm2902 (capacitors on pin 12,13 or 15,16) or the pcm2902 itself. Try checking the soldering. No ther ideas.
- Digital Line Level
- Experience with this DIY DAC ?
