adamus said:are you not getting high dc offset?
Yes - at the DAC outputs, but at the speaker terminals with normal range volume set it is 6 to 8 Mv. The Pre-amp is probably blocking the somewhat higher offset at the end of the DAC.
Be aware that Zout will be a tad on the high side when using only a 1:1 transformer out.
If we take Legarems circuit as example Zout will be 118(dacout)+1k(ser.res)+1k(ser.res)+150+150(primdcr)+150+150(secdcr)//40k(resload)=2.7kohm
Without series resistors(we can probably do that as the LL1690 should be ca 1k at 2Hz and the datasheet says min 1k AC-load), Zout is just above 700ohms.
To get a lower Zout with seriesresistors one could go for 2:1 and this gives us just above .9kohms with 1k and .5kohms with 220ohm series-resistors. If we skip the resistors we are down to ca 400ohms. The output will still be above 1Vrms.
Another, but far more complicated, way to do it, is to feed the DAC signal without caps to a differential tube(ex. 6H30) stage loaded with a 1689/PP Lundahl connected 9 or 18:1. This way Zout will be extremely low. It will probably also sound much better than using a cathode-follower. And it is completely capacitor-free.............
Hi Guys,
May I ask, which vendor are you buying from ?
Theres 3 listed on ebay with CS4397 & 4398
dac & theres 1 listed at US35.00 plus
Thks
Thks
Something like this. Output will be in the ballpark of 0dBU. By connecting the LL1689 9:1, output will be 6dB higher. R4 to be choosen for optimal loading of the chip. R2 shows Zout and should be of a lot higher value or omitted.
JC951t said:Hi Guys,
Thks
Yes, I am curious also as I would like to give one these a try but would like
to get the same unit of purposes of continuity when modifying.
These UTC A-43 transformers might be worth a try:
Ebay New UTC A-43 transformers (x16) $49!!!!!
The max level is +15dB which isn't ideal, but they are very cheap so probably worth a play.
I ordered a batch 🙂
I ordered a batch 🙂
suggestion?
Hi. I'm new in this group. Someone I know bought a pair of Digitec transfos and told me about this thread. Since I was looking a good DAC kit or something to improve the "digital side" of my audio stuff, I read with interest several posts here...
So I began to look for LOT and found some...Jensen are too expensive (so are the new Tamura) and others are very big to fit in a "regular" space like Tamura GA80080, UTC HA-108 or old Triad.
Lundhal is interesting and also Sowter:
http://www.sowter.co.uk/specs/5069.htm
and also:
http://www.sowter.co.uk/pdf/3603.pdf
with the OCC wire option:
http://www.sowter.co.uk/occ.php
But someone knows about that one?
http://www.altrancorp.com/audio_transformers.asp?id=45
and also:
the best Is Lundahl LL1690
I Intend to buy 2 pcs
are there anyone which would like to start GB for LL1690
The LL1690 has an open impedance of ca 10k and should be a good candidate.
I talked to Per Lundahl and he recommended to always use his transformers with seriesconnected primaries.
It could then be used with its primary windings in series w/o series resistors and will then have a Zout of a rather high 718 ohms when connected 1:1.
If a lower Zout is needed one could connect it 2:1 to get a Zout of 405 ohms.
the one from gigawork, does it work (out-of-box) using the USB input?
if yes, does it work with XP? vista?
thank you very much 🙂
Got a pair of LL1517. I'll give them a try.
BTW, Lundahls are the ugliest transformers I have ever seen 🙂
Just received the DAC but I need some help before to start modding, how to set dipwitches to get working the oversampling board? And to use the toslink too? Actually it's mute.... 🙁
dip switch
Check the Franz Gysi's posts, he played a bit with those switches.
piero7 said:Just received the DAC but I need some help before to start modding, how to set dipwitches to get working the oversampling board? And to use the toslink too? Actually it's mute.... 🙁
Yes it works with XP and Vista. It sounds great.
Just reverse the connection. What I meant is, set the DIP settings to COX and use TOSLINK input. It works.
Cheers!
Fred
Solved! Just mounted the digitec transformers and... I can make an hand shake with Peter Gabriel at my home!! 😀
Piero
Did you have a look at post #306 how to connect the trannies in correct phase?
And I really recommend for safety reasons to insert two 10 to 33 Ohm resistors in series with the primaries.
Remember, the Digitec's have very low DC resistance and we don't know, if the CS4398 does like this over time.
With this resistors, you have a higher DC resistance for the price of a very little bit lower level.
Franz
Franz
Franz Gysi said:Piero
Franz
I'll add the two resistors soon, I was just testing it.
Franz, I did not noticed it, but why the left channel has the input inverted and the right not?
Note: I have the digitec trannies not the studer,
- Digital Line Level
- Experience with this DIY DAC ?
