Ever think of building a Cornu Spiral horn? Now you can!
So if I took the original design for the Cornu and just stretched it would it still work???
Yes, that is how most builds on this thread are done. You just need to scale it to allow clearance for driver magnet and basket in chamber and overall dimension big enough to give good bass. Typically 28 in x 4.5 in for a 4-4.5 in class driver; 20 to 24 in x 3in for 3in driver; 14 to 16 in x 2.5 in for 2in driver. You can go crazy when using a 5in to 6.5 in driver the box can be huge at 3ft x 6 in. That is 9 square feet of baffle. Cal built a 3 footer with an RS 1354 and I think he now says all the smaller Cornu's are for girlie men 🙂
Talking about 3 foot cornu's.... X how would this one do in a 36 inch one?
Fostex FF165WK
Size 160mm/6.3”
Overall diameter 166mm/6.6”
Baffle hole diameter 146mm/5.8”
Depth 76.6mm/4.0”
Voice coil diameter 35mm/1.4”
Reproduction frequency response fs ~ 21kHz
Sound pressure level 92dB/W(1m)
Equivalent diaphragm radius a 65mm
Effective cone diameter D 130mm
Surface area of cone Sd 0.0132m2
Resonance frequency Fs 50Hz
Coil inductance Le 0.056mH
Mechanical Q Qms 4.19
Electromagnetic Q Qes 0.373
Total Q Qts 0.34
Equivalent mass Mms 9.5g
BL product (Factor force) BL 7.227Tesla/m
Compliance equivalent volume Vas 27.838L
Voice coil overhang Xmax 1.85mm
Fostex FF165WK
Size 160mm/6.3”
Depth 76.6mm/4.0”
Total Q Qts 0.34
That is a nice driver. Let me run a sim but I think Cal is on the right track and it may be a 4 ft Cornu to make this work. A sheet of sure ply 4x8 will have enough for two faces or 1 monster Cornu. It will take a lot of FC to make the channels.
