ETI Hybrid EL34 amplifier
I am a bit disappointed that you left your original idea. When the jornal came out I was almost prepared to try that design and I am even today ready to try it.
There may be an EL34 project in the pipeline w2ith some leftovers (trannies), but I have to be a bit ON- and, now OFF-topic by sharing another hybrid amp.
I'm looking at some component value tweaks that help stabilise the simulation. Dropping the value of C12/C13 from 220uF to 25uF appears to have a fairly substantial effect on it's own. Increasing C9 to 220nF appears to also help. Removing C4 & C5 on the cathode of EF86 in combination with the above appears to virtually remove the LF peak. (down to just under a 1dB rise)
Unfortunately it's not an easy job to get at the solder side of the PCB.
C12/13 are only 47uF not 220uF
