I compiled with arduino 1.0.1 and arduino 1.6.6
In arduino 101 fails to compile, in 166 it compiles but I can not find atmega644 in boards list, even if I copy atmega644 libraries in arduino hardware folder.
I will attach two text files from the two versions of arduino.
Regarding the Arduino IDE 1.66 issue, I remember reading something about having to edit some kind of preference file for it to see the atmega644. That's why I went back to 1.01
Now I get this message with 1.0.1
Binary sketch size: 26,598 bytes (of a 63,488 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
That error has to do with communications with your board. Possible causes are, No boot loader, wrong com port chosen or wrong board chosen. If I recall, I had that error when using my Macbook Air. Never did get it to work with the Mac. Had to go to a Windows machine.
I`ve uploaded the code but the display is dead.
I didn`t change the line you suggested.
Could be maybe for this?
I'm using a Rev C OLED so I include the CharacterOLED.h library. For Rev A OLED you would include OLEDFourBit.h.
It`s getting a little bit over my knowledge...
I will try to read more maybe I will get able to modify de code.
I`ll write the steps of what I`m doing maybe it`s something wrong
1. In the SabreCE folder I delete CharacterOLED.cpp and CharacterOLED.h
2. Start arduino ide and open from examples SabreCE sketch.
3. In SabreCE.ino I change this line #include "CharacterOLED.h" into //#include "CharacterOLED.h"
4. In SabreController.h I change this line //#define CHARACTER_OLED
into this one #define CHARACTER_OLED
If I do only the first 3 steps the code compiles but when uploading to controller the display it won`t light up.
If I do step 4 too the code won`t compile giving some errors.
The encoder works very strange.
Do I have to connect A and B channels to V+ with pullup resistors?
I hooked up rotary encoder today and indeed it does not work. Looking through the code i see no reference to a rotary encoder. It does not seem to be enabled. Too bad! I guess we can only hope that Robert or someone with programming ability takes an interest in this.
I don't know why but if I start the controller first and the dac after the dac doesn't catch the default volume settings, I have to restart the controller or send volume command +/-1 and it goes straight to the correct volume level.
Is yours working the same too?
I`m not using the relay command, it`s done by switches.
How do you use your dac sync or async?
Yes, mine works the same. If you turn the controller and the DAC on at the same time it seems to work OK though.
I did not think that the power relay worked. What pin are you using?
I don't use the controller to switch on anything.I have batteries powering up everything, only the controller is powered from 230vac so I need to switch on/off all modules one by one
Today arrived an apple remote and it works good after adding a filter on the power supply pins of the ir receiver.
Do you have any ideas how I can change the minimum volume level from -99dB to let`s say -60dB?
😱 Code! He posted code! 😱
I consider myself fairly smart and capable, but I am code challenged.
tried but still the same. 99 will still be the minimum
You are aware that you can set a default attenuation in the menu. Aren't you?
Yes. I was talking about max attenuation and not default startup volume.
As 100 steps are too much for me I want to use only 50-60 steps to change volume from min to max.
- Digital Line Level
- ES9018 I2C controller
