Recommended Practice?
Being new to tubes, do you guys leave the power on all the time, or turn it off when not in use? I'm curious because I had a Tungsram tube fail in about 3 months. Because it was a NOS part with unknown history, it is likely that it was just an issue with the individual tube, but I have been turning the power on and off.
In case you are curious, it failed rather suddenly and apparently during "power on". The glass was smoked near the top of the tube compared to it's mate which is clear. And no current flowing through the tube. I replaced it with a Matushita and everything works fine.
Thanks in advance.
Jac
Thanks in advance.
Jac
Thanks in advance.
Jac
Many far more expert than me, but Amphenol Thermonetics (was GE Thermonetics) make inrush current limiters which cost about $1.50 from Mouser etc. NTC thermistors have high initial resistance which drops as they heat. You have to size the thermistor for the app using the formula on the datasheet. http://amphenol-sensors.com/en/products/temperature/inrush-current-limiting/858-siweb-pl329
Here in Michigan, we have two peninsula connected by a bridge. So all of us that live in the lower peninsula are called trolls because we live under the bridge. 🙂 Of course, we don't make quality transformers.
Jac
I worked with a Yooper. He was so tight that he'd unplug the TV before he went to work.
Many far more expert than me, but Amphenol Thermonetics (was GE Thermonetics) make inrush current limiters which cost about $1.50 from Mouser etc. NTC thermistors have high initial resistance which drops as they heat. You have to size the thermistor for the app using the formula on the datasheet. Inrush Current Limiters
I'm a troll, not a Yooper, but I've still been known to turn off a light when leaving the room. Maybe I can blame that on my partially Scottish heritage.
I'm familiar with NTC thermistors on Pass amps. But that is so you don't cause a brown out in the neighborhood with the current surge "required" on a good Class A power supply. Are you suggesting this approach for B+ and B- supplies? As far as I could tell, the heater still worked. I am assuming the failure was in the signal part.
Jac
Sorry for the redundancy, but where can we acquire some of these boards? Or do we need to have them fabricated from files?
JP had a run made last fall. I think he sold all them, but I'm not sure.
The board files are available. Remember that you need 4 boards for 1 stereo pre.
Jac
Jac
The L|A articles regarding the Equal Opportunty don't go into great detail regarding the heater supply, beyond suggesting the use of the heater supply as outlined in the His Master's Noise blog post. I thought it would be prudent to have that (freely available) heater supply schematic reposted in this thread. So here it is:
I'm very anxious to begin this build. In fact, part of the delay is due to the fact I have yet to complete my Lenco turntable build. Still need a couple more parts for that one...
Furiously collecting parts for my build, I have the advantage of a preamp that has balanced inputs for it's single analog input. This is kind of a no-brainer choice, especially as I'm a big fan of the AT150MLX.
My boards are sitting sadly until I pull my finger out and complete some other things. Must do better over autumn
Furiously collecting parts for my build. This is kind of a no-brainer choice, especially as I'm a big fan of the AT150MLX.
Happy to hear it. I am interested to hear your impressions and I know you have experienced better than me.
@ Bill,
Project have a mind of their own and take as much time as they need. Not to worry.
Jac
No pressure, having talked me out of my boards 😛
@ Bill,
Jac
My problem is the projects that DO have minds of their own!
Yes, but JP, didn't you have like 24 boards in your first order? ;-)
Jac
You have no use for them, as your awesome phono solution requires no capacitors...
Bold be the man that tells another man what he needs or doesn't need. 🙂
JP and I chat in copious quantities about audio projects... It's not I who said they were superfluous to his needs... 🙂 🙂 🙂
Just because you've got a system that is the best I've ever heard, anywhere, ever... Doesn't mean that you have to stop building random DIY projects.
Oh, I've several in mind. I was referring to the current issue of having no place to put it, which is quite ironic.
Now that is a lovely picture.
I think for guys like us the saying should be changed from, "He who dies with the most toys, wins." to "He who dies with the most projects, finished or unfinished, wins."
Jac
- Analogue Source
- "Equal Opportunity" MM Pre
