Take a look at Edcors Transformers:
Power Transformers
Output Transformers
Many have had good experience. The only down side is the long wait time as they make for orders. Torroidy is good but shipping cost to this side is very high.
Power Transformers
Output Transformers
Hi pchw,
Just received my Toroidy TTG-KT88PPs as recommended by Marc.
US $26 shipping to Australia
(Ordered on the 22nd December.)
I think postage charges most reasonable, considering the weight.
Delivery was excellent, particularly over the Xmas period.
Colin
Colin
I wonder Toroidy has changed the shipper or has more shipping options.
Which shipper did you use?
4 years ago, I ordered 10 15VA small customized toroids, the shipping was double of yours, here is the quote from Tomasz:
Dear Fred,
Audio grade TS15VA PRI: 2x 115V SEC: 2x 12V costs 20,00 EUR/pc.
Shipping cost to USA for 6kg package which can takes 10 pcs. - 51,00 EUR.
According to the web page, 2 x KT88 OT's fit a 6kg package as well.
Edit: there is no shipping option to US or Canada yet.
Thanks,
Dear Fred,
Thanks,
Hi Fred,
I just used their standard online process for ordering.
The shipping cost calculated seemed reasonable; so I just proceeded with the order.
On the receipt provided with the goods, it indicates:
Transport: Koszty wysylki
The package was delivered here in Australia by UPS.
Online you should be able to replicate my experience.
(Total cost inc delivery for 2 items = $190.57 USD.)
regards,
Colin
regards,
Colin
Thanks, Colin.
26 USD is very reasonable, even shipped from the US Continental.
Unfortunately, the online ordering apps doesn't have shipping to US (or North America in general). I will send an email to inquire.
Thanks,
Thanks,
Hi drpro,
Compare the core size between the two transformers. Hammond cores are typically much larger than others with similar ratings. I looked at many before settling on Hammond products. The larger core will give you lower distortion, especially at higher power levels and low frequencies.
-Chris
-Chris
Thanks Chris, I probably will go the Hammond route for the simple reason one transformer covers all of the voltages needed. I believe this will result in a cleaner simpler build, at an increase in cost, though not a huge one. Also the wait times on the Edcor products is a bummer.
Finally got to keep sending those dollars to Canadian companies!!!
Tnx
David
Tnx
David
US $39 Taiwanese Power Transformer (from that well known site.)
Described: Good for tube radio, Amplifier
Horizontal type
Primary winding : AC0-120-230-240VAC, 50Hz
Secondary winding : V1=AC0-275V 120mA, V2=AC0-6.3V 5A, V3=AC0-5V 3A
Total power output : 79.5VA max
Note: Unit can also work on 60Hz, and total power output up to :
V1=AC0-275V 144mA, V2=AC0-6.3V 6A, V3=AC0-5V 3.6A, 95.4VA total
Core size : 96x80mm
Weight ~3kg
>> Suitable for use in monobloc application?
(Unfortunately shipping is expensive E.G. ~US $89 for 2 units to Australia)
Horizontal type
Core size : 96x80mm
Weight ~3kg
Thanks, Colin.
Thanks,
Got the quote back from Tomasz,
TTG-KT88PP EXPO version - 102,85 EUR / pc
Shipping cost to USA with the customs service - 92,50 EUR.
EXP is the potted version. About 4X as much to ship down South!!
You are welcome Phillipe. Please double check what I have entered against the BOM, just in case I dropped something from the list.
Pwr Xmer for BH with KT88s (Stereo)
Maybe we could get Edcor to do a small run of xmers for this amp? Is a stereo
amp preferred? I'd like it to handle most octal tubes. I want to see all suggestions...
Power and output transformer for KT88
May be only for those in Europe because of freight cost to US 😡 the following transformer are perfectely adapted to the KT88 version :
Power transformer (85 €) : TSTA 250/001 TOROIDY - Transformateur: toroidal audio | TME - Composants electroniques
You can use 275 V AC = 385 V DC or 330 V AC = 460 V DC but in this case you need to use 500 V DC electrolytic capacitors and 630 V DV film capacitors !
Output transformer (2 x 70 €) : TTG-KT88PP TOROIDY - Transformateur: de haut-parleur | TME - Composants electroniques
They are also available in chromed version more expensive but so beautiful 🙂 Power transformers - Internet shop Toroidy.pl
Marc
Marc
- Tubes / Valves
- EL84 Amp - Baby Huey
