El Cheapo, builders thread
The 'AQ5 can take the B+. Don't forget the cathode resistor drop. What kills tubes is exceeding dissipation limits, not Volts. The big difference between an 'AQ5 and a 6V6 is screen grid fragility. That's why the g2 resistors are 1 KOhm, not 100 Ω. 😉
FWIW, I suspect you have a "touchy" specimen.
Builders residing in "240" VAC zones can use the Triad power "iron" mentioned, as both the N-77U and the VPS24-1800 have dual primaries. Unfortunately, the Allied 6K27VF is strictly "120" VAC. Builders outside of North America need to find something else to power the B- rail. The requirements of the B- rail are modest. About 30 V., to power the CCS, and sufficient extra Volts to allow the 'T7 cathodes to follow the negative swings of the I/P signal. 40 V. should be plenty. Please observe that the schematic drops 90 V. of B- in resistors. The 6K27VF was chosen for its cost control virtues.
Sorry about resurrecting this old thread, but I finally started my "El Cheapo" project, and ordered the trafos.
Anyways, the 10k resistor between the cathodes of ECC81 and the constant current sink seems quite high, as this will cause 60V voltage loss with current of 6mA. In addition, if we assume B+ voltage of 355V, the 50k anode resistors on ECC81 will cause further voltage loss of 150V.
If I have B- voltage of say, 35 volts, would a smaller resistor, say 1k, be a better choice?
Joku,
The resistor between the 'T7 cathodes and the CCS performs 2 functions: dropping B- volts, and thermally isolating the SS parts in the CCS from tube heat. With B- down at about 35 V., use a 100 ohm carbon film part, as you have no volts to spare. All your build needs is the thermal isolation.
I started assembling it, but I started to get some weird oscillation when the global negative feedback wire is attached to output. However, when I removed the wire closing the negative feedback loop, it seemed to work fine:
Any idea where I should start debugging? I'm using Hammond 1650F output transformers.
Have gone through this thread and have a question. The Z565 has been suggested as a good OPT to use for this. That is an U/L trafo but the schematic does not show any such connections. Is it to be used without any connections to those U/L taps?
Anwesh
Hello All,
Please forgive my ignorance and lack of knowledge but is the phase splitting done in the power tubes because I was going to build this amplifier with four 6ab4's. It's easier for me to wire that way and don't know if I have matching/ability to check triode on the 6ab4's?
Thanks for the replies guys!
I didn't make myself clear as always! I have read where phase splitting can occur in a power tube which I will be using 12aq5 for the power tubes.
I would like to use four 6ab4's (1/2 a 12at7) as the driver tube and was wondering if they need to have matching triodes? I guess with CCS they don't need to match because the current is regulated.
Two cathodes that are connected to a common current source will have different currents, unless the tubes are very well matched.
Two cathodes that are connected to a common self bias resistor will have different currents, unless the tubes are very well matched.
Check what schematic you are using, to see if the cathodes are connected to either the same current source, or to the same self bias resistor.
@6A3sUMMER
Cannot remember where I read it but if you have a double triode like the 12A?7 (with separate connected filaments) and the triodes are not extremely unbalanced then you can match them by slightly changing the filament voltage for each triode.
Please be aware that DC and constant current filament supply shorten tube life. See attached article, although it is for ordinary incandescent lamps it is just as applicable to vacuum tubes. (page 5)
