Darn I waited all day for an answer, so since no one replied I bought it.
Ac adapter 34v 5a. The guys say it's not a good buy.
Afterlife2,
It's going to be fine. Don't stress over it. I think you'll find that power supply will be alright.
Later on you might want to purchase some capacitors with higher voltage ratings and swap out the original ones just to be on the safe side.
It's not very difficult to do. Find some desoldering wick/braid and maybe have someone assist you. Get all the old solder off with the braid. As much as you are able anyway. Pull up the old capacitors a bit, then just cut them off. Then you can continue to work on cleaning out the holes to accept the 50V caps.
I don't see a thing wrong with that power supply other than its rating is very close to what the present capacitors are rated for. But there's always some leeway in the ratings on capacitors.
If you are not listening at rock concert levels all should be fine.
MW
MW
Afterlife2,
MW
Phew thanks Mark. It will be used on a PC setup. I want to compare it to my SMSL SA-S3(uses a 12v 5a adapter). Can't really go too loud in an apartment, so It should be enough power. How many watts do you think I can get with TDA7498 with the new adapter 32v 5a?
Do you guys know if this case will fit? besides having the wrong holes I can always leave those sides off: New TDA7492P Bluetooth 4 0 Audio Receiver Amplifier Board Acrylic DIY Cover T6K4 | eBay
No, the sanwu TDA7498 is a little bit bigger than the TDA7492P,I would recommend you to just use an old VHS Cassette Box.
His board has smd caps.
Dang it's that big? Was thinking it was the size of a Raspberry Pi 2. I'm surprised I have not found a plastic version for it. I do have a couple of old plastic VHS cases though.
Afterlife2's board / the filter caps?
Now I'm confused. Refer to post #130 which I think is Afterlife2's purchase. Aren't all those silver 35V caps to each side of the heatsink filter caps? Those are the ones I was suggesting he upgrade if necessary (and, I think probably it is not necessary unless he's really driving it hard and has too large of a power supply).
Mark
Mark
Mark
This is the one I have: TDA7498 100W 100W 2 Channel Stereo Digital Power Amplifier Board DC 15 34V P1VX | eBay
Hey i need help witch amplifier to buy. I want 2x20 watt att 8 ohm. I am kind of new to this and would apriciate some help.
Thanks in advace.
As Pano says, you'll need to run at 15v minimum. 19v is easy and cheap with a laptop PSU.
You can probably narrow your search to boards with the TPA3116/3118 or the TDA7492. Do you want a board with integrated volume control?
As they say in NYC -- fuggetaboutit!
Afterlife2,
Yeah, right! I don't think those filter capacitors are SMD capacitors (surface mounted devices).
As I said before, just don't stress over it. I think you'll like the 7498 sound a lot. Just get your power supply, plug it in, and enjoy!
Not to slight anyone here, but people on DIY boards sometimes do have a tendency to parse stuff out and measure things to death rather than just trying it.
I was on a speaker building thread once and it was 100's of pages long. Everybody was blathering on about measuring this spec, and second guessing that spec, and showing off their "knowledge" (perceived or real). And doing all sorts of fancy computer modeling. Finally, I got frustrated and asked
if anyone had actually built anything. Few responses. Then, I quit looking at it.
I have a different board and am just running it bone stock, with zero modifications and a brick type power supply rated at 30vdc. You can spend many thousands of dollars and not get sound this good.
Have fun and enjoy your music! That's the main thing.
Mark
Afterlife2,
Mark
On that board, yes, they actually are SMD electrolytic caps. No leads on those, they solder to pads. Much faster to solder in production than thru hole. And they look to be 35V, which is nice. Should be a good amp.Afterlife2,
Understood!
Hi Pano,
I see! Thanks for the education!
Regards,
Mark
Hi Pano,
Regards,
Mark
If possible i would lite to have one with bass and trebble control or i will go with separate controlboard. The sound quality is more imortant. 18v is no problem because i am thinking of making my own batterypack.
Afterlife2,
Mark
Thanks Mark. Still waiting on the board, so I won't be able to test it out. I hope it gets here this week.
What about this one: 1pc TPA3116 Class D Amplifier Board Bluetooth 2 1 Amplifier Board 100W 2 50W | eBay
or
LM1036 HIFI Preamp Tone Board Bass Treble Volume Control Pre-amplifier Board Kit
and
TK2050 2X50W Two Channel Digital Amplifier Board HiFi Amplifier Board Super | eBay
I just orderd the amp and tonecontrol. Do you know any good cables to hook them up to eachother?
- Class D
- Ebay cheap TDA7498 boards
