Dx Blame ST together Dx Super A
I have pictures of my Dx Super A and I just need to make the holes for the heat sink and continue the build, this are my favorites pictures. 🙂 also a small video too Dx Super A build Cats, guineas, Rosters,birds - YouTube cats,rosters,birds guinea birds sounds lol 😀
Juan
Please dear friend Juan, inform your heatsink dimensions
in order to uncle charlie check if it gonna be enough or not....it looks not good enough as you gonna use a huge 45 volts supplies.
I see you will use 6 electrolitic condensers, 6800 each one of them and bypassed to ground by small capacitors.
Inform the output impedance you gonna use and if this aluminum block will be used for one or two amplifiers.
I know it is thick, but this just increase the delay time till the aluminum block reaches a temperature above the environment temperature... after that moment, when you start to exchange heat to the air, the area exposed to the air is what gonna decide your heat transference capacity.
It look small...too much small for this amplifier.
regards,
Carlos
Finally! 😀
I guess for me was really easy to adjust the bias “I’m guessing here” first I check all connections all track to make sure I don’t have lose solder around,
I’m right know testing with louder volume, wow it does have a different tone than the supercharger, it has more “life like sound” the timbre timbales drums are a lot more richer
the highs are so nice and noticeable, bass is punchy and nice, also is a lot more louder I feel the sound come out good and clear, I have the volume at 78% in my PC and is really loud
I mean it has power to it, man I’m about to be deft in a minute lol, also no distortion at all.
Set up conditions:
Power Supply +45 0 -45
trim pot to high value possible in my case 191 ohms
I use thermal compound and all main transistors…
side resistors 10R 7 watt…
so I apply power…
I check with my finger the side resistors, warm to the touch, “not hot”…
place the multimeter the voltage was really low 0.098V…
then I begin to adjust to at least get close to 1.5V I start slowly…
after about 25 minutes, I adjust again to 2.48V and wait a little more…
then I decide to leave it like that 2.48V but I still can adjust… “this my case”
I then place the RCA cables, play some music low volume first…
now I’m enjoying I’m happy happy happy !!!!!!!!!
My sincere opinion:
Sound a lot better than Dx Blame ST and MKII Supercharger, important note: it has its own timbre I do notices music come out a lot “alive”
piano good, tromped good, voices good, all instruments sound a lot better in other words. Newton told you I has no power? this baby does have lot of power.
Juan
For you ... and only because of you, i will give mine ones of special reserve
I have asked Juan to save one more pair to me..... run to catch them.
It is costing 32 USD with delivery..this is what Juan told me.... because he ordered only a few units...this increased the cost as a hell.
I am sending him message saying that you can have my boards.
regards,
Carlos
Depending people interest he may order more boards
But i do not think he will run group buy...he do not like some forum haters that goes bothering...he is a very sensitive guy, had Maya ancestors...half spanish, half native indians.... very sensitive guy...very friendly... a nice guy.
I really think he will not feel good exposed to our forum.
He already shipped two boards to me...i will have mine...i have asked him to save, if possible, two boards for my future use...more two boards to me...these ones, if really saved, will be yours....i have already sent him message saying boards goes to Roovers.
In Brasil, as usual, there's a lot of interest... and soon we gonna have local sells runned by Zimmer...do not know if he will run group buy because i do think he wants 10 percent profit...and this is against rules...he is making something simple..alike the green boards made to Dx Blame ST for Brasil...simple and cheap pcboards.
The amplifier image is not very good Patrick...without the intention to harm, some guys published scope images showing what happens with the amplifier (MKIII Hx) clipping.... so... when nobody uses this range of power...but they had worries about that.... as a result, i do think people became scared..thinking if one Dx model is not perfect... other model can be not perfect too...ahahahahahah!🙂.... we cannot go against people believe..they believe in crazy things and do not believe in people from outside earth.
Was not fast and not that easy to sell these boards.... delayed a lot dear Patrick, usually we sell this ammount in a couple of days....so... the Corporation image is wounded...a pity because this amplifier is the best one from the line.... because scared these folks will lost the change to listen the best amplifier ever made.... by the Corporation..because i have listen the NAD C390DD and it is even better.
I have build three prototypes by myself...there are videos in youtube showing them:
http://www.youtube.com/user/destroyersoueu?feature=mhee
Juan Vargas email adress:
vargasmongo@yahoo.com
vargasmongo@gmail.com
Better to use the gmail....the yahoo adress is new and i am not sure he is going to the inbox.
regards,
Carlos
Green boards i told you we have made to Brasil, are these ones
We are making the Dx Supply, to use together Class A and Super A amplifiers.... in the reality you can use with any amplifier... output voltage is stabilized withing 0.25% and voltage is adjustable from 12 to 32 volts... symetrical supply having capacitance multiplier effect (electronic filtering)...it saves capacitors and removes all noise from the mains.
Video available in youtube... test video.... type Carlos Mergulhão or use the link provided in previous posts.
regards,
Carlos
Hello destroyer X!
I am very interested in this amplifier but I have some questions.
I have Sanken 2SC2922 and 2SA1216, it is OK, ?
Transistors must be "matched"?
I have heatsink 300x120x40 (0.4 K/W) , It is OK?
Finally we can polarize this amplifier in class AB?
Thank you and any the best!
