Dx Blame MKIII-Hx - Builder's thread
Please someone confirm... .......................
On the PCB: the red path shows that the connection to the biasing transistor's collector is made through both the 22R and the 10R................
The correct tapping point to feed the output stage is from the jumdtion of the 2k2 and the 10r.
The 10r is discussed at length by D.Self. This resistor corrects the Vbe voltage for small changes in VAS current and as a results holds a more consistent output bias is the VAS current is not fixed. This is especially important where a bootstrap feed to mainatin VAS current is used. As the supply voltage varies the bootstrap current varies and thus the VAS current varies. If the 10r was omitted the output bias would vary with supply voltage.
The 10r value must be selected to suit the actual VAS current that passes through the Vbe multiplier. Self generally used 16r to 18r to suit ~6mA.
If you use more Vbe crrent then a lower value than self should be used. 10r works for about 15mA of Vas current.
Set up your Vbe with the 10r. adjust the supply current through the Vbe and measure the Vbe voltage. There should be a plateau of maximum Vbe voltage with a lower voltage either side of the optimum current for that resistor value.
post1402 needs a few correction of typos.
The correct tapping point to feed the output stage is from the junction of the 2k2 and the 10r.
The 10r is discussed at length by D.Self. This resistor corrects the Vbe voltage for small changes in VAS current and as a result holds a more consistent output bias if the VAS current is not fixed. This is especially important where a bootstrap feed to maintain VAS current is used. As the supply voltage varies the bootstrap current varies and thus the VAS current varies. If the 10r was omitted the output bias would vary with supply voltage. Note that the supply voltage varies with mains voltage and with output current.
If you use more Vbe current then a lower value than Self should be used. 10r works for about 15mA of VAS current.
Set up your Vbe with the 10r on a plug board. Adjust the supply current through the Vbe and measure the Vbe voltage. There should be a plateau of maximum Vbe voltage with a lower voltage either side of the optimum current for that resistor value.
Thanks AndrewT for the posts on the 10R resistor in collector on VBE transistor.
I was going to make a post in gereral asking about it, but then found it discussed here.
Just another question, does it make a difference if the '22uf' capacitor in drawing is over the the collector/emitter alone, or over both the ce and the 10R ?
Here is a picture of what I'm asking.
I think the capacitor should be the AC link between the VAS and it's current source/sink. The left diagram.
But others have said the capacitor should be across the bases of the output stage. The right diagram.
Two viewpoints.
Maybe careful experimentation and/or simulation to discover what the experiment should be trying to reveal.
AndrewT
I didnt know D. Self talks about this (I need to get his book), but here is an analysis on the same by Hawksford, thought you might enjoy it (if you havent seen it).
If the cap is intended to speed up the base charge removal then it should be closest to the drive transistors (the right) but since the resistor is only on the order of 10 ohms I dont think it matters signficantly.
-Antonio
