Double Bass Array
The first sentence makes sense. The second one thou? How does adding more speakers solve the distance problem?
The speakers make no difference. Only the frequency and the distance.
This is the same issue as with higher frequencies in an isobarik. The size of the room )(distance between drivers) determines the HF limit of such an array.
dave
I disagree. To completely cancel the bass the room determines the LF.
And as we know from Toole, for drivers on the same baffle to act as a single unit the drivers need to be within a quarter wavelength of each other.
But then it does not do this
The rear array must play in reverse phase to actively absorb the plane wave from the front wall.
It claims:
Sound pressure level throughout the room is very even.
Modal resonances are reduced to a minimum.
If you actively absorb from one wall, the minimum should be zero. No bass.
This is simply math juggling (IMO) to do a poor job of what Toole and Geddes are advocating.
dave
Reactions: camplo
There has been a misunderstanding. When StigErik said the rear wall array has to play in reverse phase, it also has to be delayed from the front wall.
The mention of the distance between speakers is a different issue, referring to the close spacing of the speakers on each single wall, which affects the upper frequency limit of the array.
Thanks AllenB. Also see posts #3 and #9.
more drivers won’t push frequency up, d dhould be the centre-to-centre of the furthest apart drivers.
Yes. The delay due to the room length distance is distinct from the array driver spacing distance. Driver spacing limits the ability to produce a room width plane wave at higher frequencies.
Reactions: MrKlinky and 63781
It seems like the home cinema crowd is more concerned with their low end than those bound to 2-channel music playback? 😎
I’m a bit of both - so my room and setup was built to offer the best possible sound, regardless of source type, and with high-end picture as well (4K projector and 130” screen).
To answer @Frank207be ’s question : there is no other furniture in the room than a 3-seater sofa and two small tables. However, there are som very large speakers in the room that will obstruct the wavefront from the DBA. No windows, just a door.
I'd love to have such a dedicated room but alas this isn't possible in my current home. Here I have to hide all speakers in plain sight in an L shaped room with doors, windows and furniture. Luckily my wife is very understanding and I'm allowed to have large speakers and subs (4x 21" behind the seat and 4x 15" against the front wall). I pre-measured them in REW and by playing with the levels of all Crowm XLS amps I get a response with manageable room modes at the MLP. The AVR room correction then filters away the largest room modes and I'm fairly happy with the overall result. It doesn't offer the most linear bass but it digs deep and has decent dynamic reserve for loud movies and 2-channel playback.
Nice to see you use the 2000AS/2. The older 1200AS/2 powers my L+R speakers.
Reactions: 63781
The REW room sim does not support a sloped ceiling like I have, or as many as 24 sources. I have run a simulation in a very advanced software build by a friend of mine in Comsol. The simulations were a bit off compared to the actual results. I guess there are more variables than those simulations could account for.
Meant simulating how this principle work in theory - I have found that it works great for multisub. Though i also have one sloped ceiling, it is close predicting the response.
Can’t remember how many subs REW can simulated. Think it is 6 or 8 - which according to the wiki is plenty to get a grasp what is going on.
Reactions: 63781
Here's a few more measurements. I just discovered that there were errors on previous measurements I've shown, so please disregard those.
These are done without any EQ what so ever, but with the correct delay and level on the rear array. No smoothing.
The theoretical upper frequency limit of my DBA is 136 Hz, determined by the speaker to speaker distance in the horizontal plane. And as you can see on the measurements above, the frequency response really goes wild above the upper limit, with large and narrow peaks and dips. Below, the response is a lot smoother.
Reactions: Scholl68
So it only works at frequencies where the spearation of the walls is less than the quarter wavelength?
dave
No it should be frequency independent as the 'anti' bass is played with the exact delay of sound traveling from one side to the other.
At some higher frequency it will not work anymore if the spacing between the subs is to large for wavelength played
