• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Dorati NOS DAC kits
Not sure what has happened. After mounting the through hole components (the out caps are WIMA 6.8uF 50V) the voltages are:
TP1=5.12V
TP2=2.49V
TP3=1.66V
TP8=4.99V
TP6=12.42V
TP9=12.42V
TP10=12.42V
TP12=12.42V
Marco
Hi Marco,
To better assess your soldering, clean the board in 90% Isopropyl alcohol and a soft bristle brush. I can’t be sure but looks like you have several places where cold solder joints can be giving you some issues.
Shouldn’t the values of C11 and C16 be much larger than Wima film caps will provide?
Marco - what I think likely has happened is putting the inductors in circuit has exposed an issue with the earlier soldered parts, those around the DAC chips.
Please measure the voltages on the TDA1387s pin6 and pin8. All pin6 are connected together, as are pin8 so you only need choose one chip to measure its pin6/8 voltages.
R56 won't cause the symptoms you're seeing if it were absent or disconnected.
The problem must be with R57,R58 (could be open circuit), R53,R54 (also could be open circuit) or two of the transistors Q17,Q18,Q19 & Q20.
The correct voltage across R57,R58 is 0.7V.
Hi Richard, my Dorati was working perfectly until I started putting it into a nice enclosure and now I don't have any output on the left channel - I didn't suppose the enclosure was actually the problem so I've taken some measurements and would welcome your opinion. The fact that one channel is working correctly means that the digital front en is OK and the issue is likely to be in the analogue filter/output stage of the left channel.
Firstly the complete set of test point measurements:
TP1 - 4.9V
TP2 - 2.5V
TP3 - 1.7V
TP4 - 4.7V
TP6 - 6.0V
TP7 - 4.6V
TP8 - 5.0V
TP9 - 7.3V
TP10 - 5.9V
TP12 - 12.1V
All look OK except for TP12, which suggests the problem is with the final stage of the left channel output, so I took some more measurements and annotated the schematic as per attachment. The voltages in orange are for the left channel and those in green are for the right channel.
It looks as though the problem is around Q10, Q13. The soldering looks good and I can't see any bridges (and it worked previously) so I'm thinking a part replacement is required? what do you think?
Hi Ray - my suspicion falls on Q14, it maybe has failed. Check its base voltage (pin1 on schematic).
The measurement you have for Q14 emitter (pin2) looks improbable, its higher than Q9's emitter but there's no way to make it so high, other than a short on the PCB. Oh, it could be that your 11.18V measurement is in error, seeing you have two voltages for the same net. That the 11.18V is wrong would explain it.
Hi again Richard. After some distractions I got back to the Dorati DAC today and have checked previous measurements and included some more - see the schematic below. As before, the voltages in orange are for the bad (left) channel and those in green are for the good (right) channel. I added some diagrams for Q9 and Q14 to keep the annotation clearer. Thoughts?
