diyAudio Full Range Reference Project
And for good measure if someone wants to try it a folded ML-Voigt
loninappleton said:
And these were built from the drawings at post 539?
Yes, we just scabbed on a couple extra pieces on the side to give them the same aspect as the Fostex FE126 design... if you were building from scratch you would just make the sides extend down.
What would a stand height be on these or can they be
used a 29 " desk height?
That is the other way to do it... as a stand-mounter... like Scot's attached.
dave
Thanks for clarifying. This reference project seems to
have morphed into a number of designs all with the same
FE127 driver.
That being the case, and since GM has already given a
MLTL design for this (which I built) are there any tweaks
based on theory to go in that direction? Any design
suggestions to improve on that? I'm curious about
triangular shapes and long port tubes as in some of the
builds of the Jordan 92s.
dave
Dave I don't want to criticize, but Scott left the staples in the upper corners of his cabinets. It must have been pretty tough running the router over those. :angel:
Yep, Scott's got a lotta 'splining to do bout dat!
Best Regards,
TerryO
Terry Terry Terry.........
You make me laugh everytime you write.
When I was dry fitting those cabinets I was having a heck of a time holding the corners together. I was intending to glue and clamp the box up in a single process so I decided to put a spline in the corners. Since I could not make it disapear I decided to make it into a bit of an accent. I have a pretty good collection of Western Yew wood so it makes a logical choice.
I hope you can make up to Al's for the get together, I am sure between you me and Cal we can cause a great deal of havoc and poke fun at most everybody in our extended audio family.
I hope Jason has enough business cards, so you can get one too
Thanks for the comments
I'd like to come too... but i am in ny.
The only time i feel a sub is needed with my 127e is when i turn it on.
http://www.zillaspeak.com/fostex127eStraightPipe.asp
Otherwise the bass is bouncy good fun (within reason of course). Problem with this driver (and it's a really good driver) is that it sometimes sounds hyper... and too forward. Other times it sounds really great. It's detailed and a very good compromise as a full ranger goes.
Soon i plan to build something similar to the monopole designs... same volume but with a shape more similar to that wide and flat omega i've seen. It looks so elegant and would fit nicely in my living room.
I'm curious to see how the ported design compares to the pipe.
Peace,
Godzilla
Tombstone:
I hope this works. I got Planet10 to draw this up for me. It breaks the curve up into 20 segments. Set the table saw at 4.5 degrees and cut the sections. Use 3/4 in material. You may need to make a male or female mold for clamping and use a glue with long set time to allow for some fussing about.
If the diagram does not work maybe dave can find the one he did for me.
Good luck
I have not tried it yet
loninappleton said:
The Kerfcore stuff is still pretty hard to find though.
Greets!
I use to make my own kerfcore out of marine grade plywood till a business trip to a mil-spec parts supplier brought these folks to my attention: http://www.baltek.com/applications/aerospace.html
I ordered mine from a local marine supply house. Not particularly cheap, but it sure beat making what seemed like a kazillion slits in 3/4" ply just to make two horns.
GM
asoprs said:
has anyone built the "tombstone" style of this cabinet. I have a pair of these drivers and want to try this cabinet. Just wondering if the larger front baffle on the tombstone would improve th bass a bit as i have no sub.
It won't outright improve the bass but will lower the point at which baffle step starts taking place... push the cab back near a wall and any BSC requirements could be eliminated.
dave
MarkMcK said:
... Fostex’ banana paper cones are very noisy with vibration modes. They are much worse than polypropylene or the mag/AL alloy... Cone vibration modes may be independent, loosely coupled, or tightly coupled. Fortunately, several vibration modes in the FE126E cone are tightly coupled. That means that controlling one mode may take care of more than one... two regions of the cone are mechanically modified... The critical regions where the mechanical modifications are made are 9 and 17 mm in from the outside edge of the cone.
http://fullrangedriver.com/forum/viewtopic.php?pid=4861#p4861
dave
planet10 said:
Sure they would -- sealed (or aperiodic if you want a smaller) box XOed to sub(s)
A box between 3 & 10 litres with an XO of 150 to 115 Hz....
With the success of planet_10 sealed bi-pole for the WR/FR125:
http://www.planet10-hifi.com/sealed.html
I was wondering if anyone has tried a sealed bi-pole for the FE127E?
I have noticed that my BD-Pipes start to suffer in the mid-range (and get ugly in the bass) with increasing driver displacement.
I was thinking that a sealed box may help limit the driver displacement, thus delivering a better mid-range.
The problem is see with a sealed box is that with an F3=120 Hz (23L), a subwoofer would have to cross over at about 100-110Hz and you may be able to locate it. Or, do you think I could count on some bass reinforcement from the room and cross the sub at 80-90Hz?
Anyway, I am always interested in hearing what the others think as I am not sure if I should go t-line or sealed.
Gio.
