DIYA store "Wolverine" (Son of Badger) .... suggestions ??
OS do a small tweak to C113 pitch distance 5 mm, 7.5 mm, and 10 mm don't mind my cat Pushi 😛
  • 2021-04-10 09-11-25.mp4
    2 MB
  • C113 macro.zip
    C113 macro.zip
A few little bugs ...
Silk tweaked ,
R25 named /changed to 5K , R23/24 lowered to 22-27K. D4-7 need more current for stable +/- 1.2V reference. (below)
Bourns 3260 side adj. trimpot needed a new Macro.
DRC run , fixed silk on pads errors.
OS
D3 is optional and not connected to facilitate simulation. 4148 model , I take
a 4ppm penalty. I lost my "BAV " diode model.
I will note D3 as an option.
Same with C4a/b. A or B jumpered with the other at 47-68pF will be
CMC (miller). C4a +b , 56p/270p to 100p/470p is TMC.
CMC = no R20 .... TMC = R20 - 2.7K.
Oh , by the way ... JW - check holes , this was the big complaint on the
Badger. 😱
OS
I'll give everything a thorough final check before ordering boards. There will likely be people complaining about 1/2W resistors not fitting throughout the amp, but that's just silly anyways.
Did you have emitter resistors in mind for the output devices or is a pair of generic 3W resistors meant to go there?
I could do the same test on some of the transistors we are looking at for this design if it would be helpful.
That shows the KSC1845 has a Early voltage of about 120. Rco in the quasi-saturation model would be in the very rough ballpark of 214 ohms. The best source I had for making models was DCA75 Pro data from ASTX, but the noise in that data was very high. I used up to 5-point smoothing and still couldn't determine Early voltage on some of the transistors.
I think the available models are good enough for this amp.
12 - .5R/Vishay RS02B/M or anal NS (Ayrton-Perry winding) 3 watter's , 14mm body/16mm LS . About 20$$
For cheap , 6 - .22R (KOA BPR58) 15mm LS ceramics. ($3.60)
OS
I just did a quick comparison on hole sizes between Diptrace an the Wolverine board. Diptrace 1/4W resistors have a .96mm hole instead of .8mm. Same for the headers. 1/2W and 1W resistors have a 1.17mm hole size instead of 1mm. Emitter resistors are 1.7mm instead of 1.2.
Is there an easy way to alter these in Sprint?
0.8mm holes are huge, no need to make it bigger.
Here is a picture i just took of components placed in a 0.8mm plated through hole pcb, from JLC.
Even 1 1N4007 fits without forcing.
For comparison 1.2mm and 1.4mm. I don't see why emitter resistors should be 1.7mm.
In all honesty most components fit in 0.8mm holes. so i think OS's sizes are realistic.
Does that mean diptrace is right ?
Those 2 big resistors (KOA and Vishay) are .8mm +/- .1mm. If those specs are right ... no issue w/ 1mm.
Too big a hole would make populating the board more difficult.
All the small stuff (TO-92 ,1/4w R's,1n914s ,trimmers) , are .62mm (+/- .1mm).
Inductor coils (2mm) , NJW0281 is 1mm +/- .2mm.
TTC004b is .75mm +/- .15mm .... So , .9mm max - I'm at 1mm for those.
I looked at a LOT of datasheets to not repeat the Badger mistakes.
At least 10% over MAX spec. on all.
OS
I've assembled tons of boards with the patterns used in Diptrace and everything fit's nicely. Most of the patterns are drawn from manufacturer's recommended pad sizes. Having too large a hole won't make things harder to assemble, it'll just cause more alloy distortion for the crowd that thinks the blue wire sounds better than the red one.
