Well, all of these heat sinks in the Sony Vfet amps are the same through the TA 8550 series. In the 8550, the heat sink holds six VFET's operating at about 100 watts relatively high bias class AB, which should mean that it should disperse up to 100-200W or so of heat, so 90 watts or so could be within spec. for one. The idle power draw of the TAN 8550 is 260 watts into two heat sinks, so I would speculate that a good bit of that dissipation would be in the heat sinks. Even the power consumption of the TA 4650 is 270 watts. There was one article in the day that measured the 4650 at 60 w RMS per channel with about 1 percent THD, so it was like many of the high end products in those days underspecified. I know there are issues of rate of heat flow and dispersion etc. but it is worth a bench test and I will report if I catch on fire or blow myself up in the process. I would give it 50/50 that it is OK with one heat sink and certainly OK with two, and maybe 3/10 that I complete this project and get something working, but I hope it will be fun and interesting along the way.
