DIY Sony VFET Builders thread
Thanks Super.
Got my amp up and running. Sweet, Im pretty happy with it. Set it up to +20VDC and ran it for 15 mins or so. The LH side VFET is getting about 5 deg C warmer than the RH side one, as its more tucked behind an internal heatsink fin I suspect.
Still, the VFETs arent getting any hotter than 42 deg C and 38(ish) deg C respectively for the LH and RH sides. Im measuring with a laser thermometer.
Sounds great. I was even able to install Super Through speaker caps (after this pic was taken) and the SMPS still ran fine. I'd just like to roll the input cap now.
At some stage I'd also like to install a linear PSU (what secondary voltages in a trafo would we look for, around 25VAC x 2?)
Excellent work and 42C is cool in my books (after all 57 watts / chan heat dissipation is easy to work with). As for linear power supply, 24 VAC is fine in full wave rectification.
I would be keen to find out if others have explored the linear power supply option and have found there's an audible difference?
I would also be keen to hear this.
Plus from anyone who has rolled the input coupling cap.
Here's my finished franken-beast.
Very happy, velvety-smooth & detailed sound.
Thanks so much Nelson and everyone else involved who made this happen!
^ That chassis turned out quite nicely. :up:
A linear supply will need to start with more than 25V secondaries from the power transformers. 28V secondaries will probably work if you have good low Vf bridge rectifiers. I used a pair of Triad 160VA transformers with 30V secondaries and single rail SLB CapMx boards.
Note:
The linear PSU will require some effort to reduce the hum to a level that is as inaudible as the kit SMPS. I suggest a CLCRC filter or the SLB.
I still have 2 outstanding mods on my side...
- The bypass caps at the 10000uF output caps, hopefully next week time permitting (it is very quickly done but I am overloaded since 4 weeks)
- The SMPS filters in front of each output board, likely to take a bit more time as I want them quickly removable to carry out quick tests with and without it
Argh, need really more time, but, err... isn't this just a hobby to waste some time, so... 🙂
Will of course report as ever once done
Claude
@ MEPER
You can find them in this thread V-FET / SIT data sheets
Edit + V-FET / SIT data sheets
Thank you!
I probably better find a 2SJ28 and not try to experiment with 2SJ26 ....which is a Yamaha?
I wonder who actual produced these? ......Toshiba? or had Sony their own silicon factory? ......I guess Yamaha did not?
If I get the full PDF data sheet for 2SJ28.....can I in there see the difference between KF-33, KE-33 etc.....?
Nobody produced actually these V-Fets, the Yamahas are also obsolet.
I guess, you will be sucessful with your search for 2SJ28, it may take time. Think of looking only for 1, may be easier and as far as I remember you have only in one channel strange noises. Matching is not important.
