Hertzblaster bro,
please share some gyan, it seems i am lot behind in these thing.
please tell what is the resolution of 7" lcd you are using, and what triplet lens you are using, what fl.
I wonder why Sir Hertz didn't update this thread, hmmm he's busy doing his experiments...
anyway Viki, for your satisfaction... i'm one of students of Sir Hertz (DIYPJPhils) and here's what u need to know:
Innolux 7 inch widescreen LCD Panel
Native Resolution: 800x480
Contrast: 500:1
Controller Inputs: VGA, Composite and S-Video
Projection lens 265 mm focal
Fresnel lens 220/120mm focal
We're using LED as of the moment... mine is 80W 32V@2.8Amps
I think this is the first Water Cooled LED projector.
TipidPC.com | DIY: Build your own LCD projector for dvd playback and gaming
There's alot on Ebay.
Yes,
there are lots on e bay, But i still cannot believe that those 7 inch lcds would be able to provide the quality, Which you have shown in your projector.
Can you guide to any such good link for lcd. It will be greatly helpful, If possible the seller from whom you purchased.
Any ways good luck for your diy and thank you.
Shenzhen FEELWORLD Technology Co., Ltd Feelworld
I buy LCD by 100pcs. But you can ask for sample first but its going to be expensive.
Its owned by Liliput China.
BOE 1280x800
COntroller: HDMI/TUNER/Vga/Ypbpr/Svideo/Composite/Audio
LED: 128w 13,000 lumens. Customed designed with the manufacturer.
DIY led controller using LM338t
fresnel: 220/150 focal
aspheric condenser lens:75mm focal
projeciton lens: 265mm
Water Cooling: 120x120mm aluminum radiator
diy aluminum water block
280L/hr submersibkle pump
Image is brighter than my 250w HSD bulb!
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- diy projector from the Philippines
