Dear hertzblaster sir,
can you tell me whether a small LCD with HDMI or DVI available?.
Also can you post the ebay link to AUO 10.1 inch B101EW02 or similar LCDs. My search reveals links only to panels.
The controller is programmed for me by the big controller supplier in China which specializes in big LCD TV controller. They don't entertain small orders.
Dear Hertz sir.
I am a true fan of diy projector idea.and of course yours :--).
what I am getting locally.220/330 fresnel(310mmX310mm),345 triplet,15.6 benqG61hdal lcd,400w bulb.now problem is 310mm wont cover full 15.6 lcd(350mm lenghwise),and if I use 4:3 mode of the lcd to use it with 310mm fresnel,there will be picture distortion.and I live in india,there is a lot of problem with customs,taxes etc if I bring lcd+controller from other places.can you suggest me something by which I can use this lense with this lcd.
another question.of course it is a proven fact from your builds that led will give better picture,but led and led driver is not available locally.do you have led+drivers?
also suggest me that this 15.6 benqG61hdal,regarding FFC issue and stripping,other things(picture quality) I can compromis.
thank you very much sir for your help.
new student prosenjit from india
dear prosenjit
U can order 400 x 320mm fresnel from optolife dot com for ur LCD.they are most trusted and u can get all diy projector parts from them .There is no customs problem and i have received my parts just yesterday.
regards
Srinivasan
regards
Srinivasan
400x320mm are mostly defective. There is a problem in center groove and the outer groove. You get a brown dot at the center bec of 220mm fresnel. And bec of defects in outer grrove, you ll get considerably low brightness at the sides.
I ordered samples from different fresnel suppliers popularly known in this site. .
The 395x395mm is the best quality fresnel for 15-16 inch lcd.
Oops ,i received it.😱. ok let me try this and order from 3dlens dot com in future.
hertz sir
i did my pj with 220/330/310 and with benq 15inch monitor. absolutely no problem, watched 2 movies, and the next day when i tried to finalise my design and close the box, i have damaged the LCD. there is some vertical lines in two three places, any idea to correct it
dear Hertz sir
I find your image is going out of the screen. any screen size upgrade in future ?
New Build 7 inch 800x480 w/ HDMI/VGA/Ypbpr. Excellent brightness and color saturation using 98w led.
Box comparison w/ B101EW05. DVD on top to size up the box.
Holy....Sh!!!!!!!T.. thats one high def screen its projecting.. man i loved this project and im going to make one like this soon.. @hertz..
I dont want my projector to be a low-def projector..
Sorry if the english is bad i am not very good at it at the moment.. Im from PAkistan!!!
Anyways..
Heres is my projector components which is have chosen so far, and going for shopping 😛 in a couple of days as soon as my pay-check arrives !! 😉
LCD Panel - Any 15inch Panel with 500:1 C.R. & 1024*768
CONDENSER LENS - 127mm FL
COLLECTOR fresnel: 330mm
COLLIMATOR fresnel: 220mm
Projections Lens - 340 mm 74mm diameter Triplet Lens
250W Metal Hallide Osram HQI-BT,(UV protected) with Magnetic Ballast
Heat Shield - Tempered Glass
A couple of Fans, Heatsinks and some misc parts necessary to build the projector..
Any suggestions would be nice.. I want to be a bit low on lcd budget this time because i dont want to mess a new Hd lcd for my first build(i know i would mess it up) so rather i would buy 2 LCD's which i can easily find at about ~$50/each
Anyways..
I already bought 120 inches screen. Still using B101EW05+126w LED+140mm collimator fresnel
contrast and response time
Hi
I've been toying with the idea of a diy projector, and am finding your information very helpful. Thanks!
I was wondering about the response time on the panel you're using. The specsheet shows it to be 25-35ms, which is a bit high. Do you find that a problem for viewing video? I was also looking at the B101EW02. It only has a contrast of 500, but a response time of 16. Which do you think would be a better choice?
Take care
-J-
Hi
Take care
-J-
Hi
Take care
-J-
I built them both.
If only I can have the best of them in one lcd, then it will be awesome.
But B101EW05 wins hands down. white and Black level, flesh tone, colors and detail is georeous!
They both have the same lag when camera pans in different direction. In fast action scenes, depends on how fast the action scenes is.
But I have to warn you, the controller plays a crucial role in image quality in any lcd.
I probably holds the record on the number of diyprojector built. lol!
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- diy projector from the Philippines
