DIY Front End 2022
K209s work, too. :clown: OK, I’m done for now. Thanks for the guidance, Ben and Lucian.
Finished.
My FE2022 -preamp is in the cases.
Chassis 1: PSU
Chassis 2: preamp
Chassis 3: PAC (pre amp controller) = input selection and volume control (also used for other preamps)
Cheers
Dirk
Hello Aleph5,
I've posted about PAC. I'm not sure, but if I remember right, it was in the BA2018 - preamp thread.
But these pcbs are not from me. It is based on an ARDUINO NANO as controller. You can 'hang' a lot of input - pcbs and
volume control pcbs on it.
All the other pcbs (FE2022 / PSU) I did myself in KiCAD.
Can check if the PCBs for input and volume control are still available. German DIY-shop.
Cheers
Dirk
Reactions: Aleph5
After listening to precariously placed FE boards for a couple weeks, I installed them permanently in the amp. Rats' nest be damned, the things have a totally silent background. They sound great, of course. Just the right amount of gain.
PROBLEM: I just completed my FE. Hooked it up to my system and turned on my CD player then my FE and then my ACA mini. When I turned on the mini I heard a good pop through the speakers. Hit play on the CD player and everything sounded really great! Also during idle there is a very faint hum in the speakers. It's mounted in a small Galaxy case.
