DIY Front End 2022
I believe the specified caps are actually polyester or PET, and not polypropylene. Hence the smaller package. Also, some like to avoid caps with leads that are identified as steel, such as many from Panasonic, though some lead materials are not easily identified.
Tried so many combinations of R6 and R7.
Now everything backed to the values of Pass' reference circuit, only changed R7 to 1K. Now the offset reduced to 0.1V.
Looks like in the correct direction.
Now I understand why the essential kit has to have R7 and R8 and semis picked by Mr.Pass.
Reactions: cubicincher
Spice file for Nelson's circuit to play with
The smallest distortions in the presented scheme can be achieved by changing R6 within small limits. If anyone needs it here.
  • NP DIY FE 2023_mod.asc
Depends on the output transistors. The article shows a 10 Kohm in parallel with 1 nF load, @ 2.8V and the distortion goes
from around .0025% at 1 KHz to .005% at 20 Khz. As you increase the capacitance at 20 KHz it climbs to .01% at 2 nF
and .05% at 5 nF. Above this capacitance and/or amplitude it continues to climb, showing a negative phase 2nd harmonic.
In a MUFF the Cgd of a single output is the dominant load, and in the parts I have used ranges from 150 pF for the IRFP240
Mosfet to 200 pF for the Sony VFET to 800 pF for 2SK77 VFET to 3 nF for the 2SK182.
The 2SK182 is a bit of a stretch, but it depends on how hard you push it. I haven't noticed any subjective issues that I
would attribute to Gate capacitance, but I haven't tried it on an X1000...
:snail:
Reactions: adason and Vix
You can use this to drive the M2 output stage with IRFP240/9240.
Especially if you close the outer loop.
https://www.diyaudio.com/community/...in-class-a-b-and-maybe-a-power-whammy.390636/
Quote from the article :
"The J113 and KSA992 have been shown to stand up to 70 volts maximum in testing,
but I am suggesting that a 50 volt supply is appropriate and allows use of 2SK170 type and other Jfets as well."
So maybe you dare to use +/-25V supplies. 🙂
Patrick
I have used my +-20V supply - so, I am 5 steps/ volts from the positive target-rail as well 5 steps/ volts from negative target-rail away.
For me, this means 10 steps to F.A.B. - membership minimum... :yes:
Have fun playing with this circuit! Simple and good - very similar what I did a few years ago with ZVN/ZVP3310 and added CCS from the DIY Op Amp-article. https://www.firstwatt.com/pdf/art_diy_opamp.pdf
Railvoltages were +-32 V! I've built fig. 4 / page 7.
Cheers
Dirk
