DIY Class A/B Amp The "Wolverine" build thread
This set up worked well for me.
The 2 transistors Q101/Q102 used for the capacitor multipliers, if I use 3503D and 1381E, will the hfe difference have a big impact?
Further to this for higher V rail options use the 3503D/1281E and choose higher gain parts.
For lower rail options use the TTA004B/TTA004C since they typically have higher gain than the 3503D/1281E
Check out the line in the BOM related to this also.
Hope this helps
- Dan
Nope, you're fine. We looked into this recently.
Both TTC/TTA004 and (XXX)3503X/1381X parts work in the cap multi position for all rail configurations.
TTC/TTA004 are preferred due to typically having ~200 hFE vs the ~90-130 of the 3503/1381.
That said, either work fine and there'd be miniscule difference.
It's the predrivers and VAS where rail voltage becomes a real concern.
