Variac said:That Rockna-line kit seems to do the job!
Has anyone else had good dealings with them?
I just finished to assemble mine (after more than a year
Cheers
Andrea
I've compiled the source code with ASEM51 (because I've put the LCD texts in my language - slovenian) without any problem. Player works fine !
Cheers
Cheers
bostjancek said:
It's work, so easy to compile & no need to rewrite source code.
I have a couple of maxim 89c420 - 40dip
would they run MCLL's code without alteration?
-Don't think I'm up for learning a new architecture right now
davesaudio said:I have a couple of maxim 89c420 - 40dip
-Don't think I'm up for learning a new architecture right now![]()
Refer to datasheet of maxim 89c420 - 40dip, it should be OK but I don't have 89c420 - 40dip to testing...
I started to make a CD player based on a CD Rom when I found this thread. I hardly ever use any other buttons than play,stop & Eject so I thought it was going to be easy. However I did not consider things like faster than 1X reading and the fact that the damn disc will spin in the CD Rom even when you press stop. Also problems with copy protection bypassed me.
I've had a look at MCLL's controller, you have a very neat thing there!!
Does it deal with copy protection issues & does it force 1x speed to read CD's.
I have never programmed a microcontroller before and my programming experience is learning basic in primary school, I was about 8 yrs then and thats many years ago.
I was hoping this could be a good introduction for me. I've downloaded the source code & the diagrams. Apart from a suitable programmer with software and the will not to end it all if it goes wrong, can anyone give me some pointers.
Things like useful advice, places to buy a simple but good programmer etc etc.
All I have to offer so far is a pic of my project as it stands. Its a bit of a no brainer at the moment. I got a 2U rack mount case and lined it with chip board & made a chipboard plinth in the middle to raise the cd rom. It's going to be a top loader. I removed the drawer and intend to modify the opening mechanism so that it locks the top cover on the case rather than ejecting the disc.
The PSU is a switchmode that I hacked. I played around with various ideas before I got this far. Each cap is 3300uf & the 1st stage is a RC filter of 6600uf & 1.2R. The resistors are on the small heat sink. The switchmodes output without the filtering was quite good. I was surprised at this. With the extra filtering and shielding the output is very clean as far as I can tell. My scope is basic and measures down to 1mv and can give noise figures down to -75db. I cant even get a noise reading with this supply.
Hopefully it wont be long before I have a decent controller for it.
Then its the DAC but thats anothr story.
Cheers Paul
Cheers Paul
Finding CD Rom ATA controler KIT
Hello, some body can help me to find one complete controler Kit like: http://www.diyzone.net/article.php?sid=195. How i can purchase it?, some body know how much is it?
Thanks, and best regards...
Using Slim CD Converter to Connect CD-Rom Controller
http://www.bixnet.com/notslimcdtod.html
Remember! Slim CD MUST be Selected to 'MASTER', CSEL MUST be connect to GND. BUT, Some brand name Slim CD cannot be... I don't know...
Wow, that's very nice. I knew you did that!
Could someone send me a controller chip for free? I wanna work on this one.
IIRC I had to hack the CSEL on my board as my Lappy CD was set up for CSEL only. IIRC a pullup on the CSEL solved it.
D
- Digital Source
- DIY CD drive based on a computer CDROM
