DIY ACA mini
The gonna be:
4ch summer amp 🤘🙂👍
Reactions: A Jedi and von Ah
gave it 1 more go and had success removing the mosfets!
With both trimpots on minimum, VO = 11.69V and VB = 0mV. Trimpots on max, VO = 11.69V and VB = 0mV
OK, ignore my previous arrangement mentioning VO and VB
Papa should include these points in schm, dammit
anyway, with mosfets out of circuit
both trimpots to zero
connect black probe to + Rail, red probe to G pin of Q3 (most left pad) , write voltage
connect black probe to GND, red probe to G pin of Q4 (most left pad) , write voltage
both trimpots to max
all ref to this, taken ditto from article
Hey there, I kinda knew that going in, the bottom is drilled out to allow air to come in from under the board and disperse throughout. The feet on the bottom raise it an inch off of the other component, which is not used at the same time. I may completely remove the lid as well. I do have a temp gun and will be checking on it. That box was on my desk when I first started reading about the mini, and it made me pull the trigger on it. I figured I had to try and get it in there. It may not stay forever.
Reactions: A Jedi
I don't think that is quite enough money to accomplish a whole first-watt build. At least not any of the 25-watt variants without scrambling or making a chassis. Especially with the price increases of parts etc over the past few years.
I know I am not Pass but I have heard the PA-5II. it is a nice-sounding amp. I like the way a lot of these class A first-watt amps sound better. If the PA-5 had the front end separate from the amp board, I would say grab it as you could do a lot with that.
Reactions: St. Peter(sburg)
I forgot to post my finished amp, here it is, for now
Nice... I got a B1 in a humidor... it runs great... hasn't burned the house down yet.
I got a large wine bottle box, Daou, fits 6 bottles, with a hinged top. 12"x15"x9". The plan is to put an already built Mini in there. I figure I can always open the lid when I play the amp.
Cigars, wine and 2nd harmonic go together hand in hand.
The PA5 and PA7 are much more desirable in their Mk I iterations... the ones that prompted the copyright lawsuit. The PA7-I, in particular, is considered to be the poor man's amplifier for Maggies. Unfortunately, they are no longer "cheap". I figure you could build the A2s kits for less than a PA7-I.
To run a stereo ACA mini at the bias levels Pass recommends? I wouldn’t recommend it.
In Pass‘ ACA mini article (even without knowing anything regarding the bias), Pass recommends a regulated 24V DC, 90 watt Meanwell supply.
The WHAMMY however, uses a 25VA (i.e. close to 25 watts, but not exactly) Toroid for the stereo headphone amp.
Best,
Anand.
Reactions: spind
Thanks for clarifying. I didn’t know the store kits come with a 48W SMPS. That changes things.
If you have (2) Whammy PSU’s, i.e. (2) of the 25VA Toroids, then that may be doable.
I usually try to be conservative, given that the encapsulated Toroids in the Whammy (i.e. not Antek) will heat up since they don’t have free ventilation. This being Class A and all where the bias is constant. Usually 50% is my rule. In example, my MOFO build uses a 120VA SMPS for a circuit that requires 60 watts (24V @ 2.5A). Even then the SMPS sits at 40 degrees C with the amp cover open and close to 50 degrees C with the cover on.
I haven’t looked at the bias requirements for the ACA mini, but I probably should…better yet, I’ll hook it up to my bench supply (which measures the current draw) once I’m done building it.
Best,
Anand.
