Digitally controlled preamp/headphone amp
Thanks! 😀
On first glance I think there may be an undefined variable or two, though I didn't really look that hard. I'll have to reboot my computer into Windows to really go to town on this. All I really needed is the code to write data to the PGA2311 so I didn't have to read through the datasheet and figure it out. Timing diagrams give me a head ache.
Re: "Perch" layout
Russ White said:
Ok so I created a perch on which to nest up to 8 kooks. 🙂Hre is the layout. I will make one and test it with a stero channel and a subwoofer amp. Lets see how she flies. 🙂
Anyway if it works I may be willing to make a couple (self etched) for one or two people if any of you guys are seriously interested in making a go of it.
board size is 1.5" x 4"
Cheers!
Russ
that would be great !
I'll be awaiting your tests
grts
Hi all,
I want to buy some PGA2311PA (DIL) in Europe for my needs. Who is selling them here ? Where do you buy yours ?
Not Farnell that don't want to sell to hobbyists, even buying many PGAs.
Thank you for your help.
Best regards.
rephil
maxlorenz said:
Hi Russ and Brian:
Here I am, still waiting for the TX's to arrive. 🙁
While I wait, I want to ask you a question (I'm sure I saw the answer somewhere but can't find it now).
To connect Kookaburra to My-ref the output buffer from Kook could be obviated, right?
If so, where do you connect the outputs or where do you put jumpers?
Thankz :angel:
Mauricio
Yes it can, You really only need the output buffer for loads less than 600ohm.
I will post a photo of where to put the jumper as soon as I get home where I have them. I am at work right now.
Notice that on the PCB silkscreen there are two white lines between two pins on both sides of the output buffer. Just use a piece of wire or discraded resistor lead to jumper those two holes on each side.
Cheers!
Russ
pic...
Re: An idea gone wild
Russ White said:
So for each pot header you would attach a 25K pot. And for the mast volume you would use a 10K pot.
Russ [/B]
hi,
how are those tests going with the multi kook perch and power supply?
i wonder if I can use different values voor those pots, how much effect would it have if i put 20k pots instead of the 25k pots?
the reason would be: to find motorised pots of 25 k is a pain, but 10k and 20k are easily available by alps
greetz
PS does anyone know where i can find more info on the panasonic motorised pots? can seem te find the available values 🙁
Russ White said:
The value of the pot are not critical, just need to be high enough so that when in parallel they don't overload the buffer. A buffer after the "master" pot is important. 20K should be just fine.
What about the Kook as is NOT muti, can a 10 or 20K motorized pot be used? Because I sure can't find a motorized 5K!!!!!
Mike
