Digital Designs Z2HV
There are 2 pnp and 2 npn driver transistors per bank of fets
so 3 fets have 1 pair of drivers the other 3 fets have another set of drivers .
So I’m having issues with both sets of drivers or a transformer is shorted or something .
The drive signal looks good with a loading cap but as soon as the fets are installed the drive signal goes bad .
here is what I get as far as resistance
Q9-Q9A 94.1 ohms
Q9-Q9B 94.1 ohms
Q9A-Q9B 94.1 ohms
Then
Q12-Q12A 93.3 ohms
Q12-Q12B 93 ohms
Q12A-Q12B 93.1 ohms
Q9-Q12 is 1.020K ohms
These readings match all of the other banks of fets as well .
I removed the 4148’s
I still get 93 ohms from gate pad to gate pad on Q9,Q9A,Q9B and 1k ohms from Q9 to Q12 this is how it’s supposed to be I’m guessing since all of the other banks have the same measurements
Q9,Q9A,Q9B are driven by Q7B,Q8B drivers
Q12,Q12A,Q12B are driven by Q7C,Q8C drivers
Here is what I get on Q9,Q12 the rest of the drives signals to the other fets in the bank are identical
Ok I replaced the diodes and it fixed the problem . Thanks greatly appreciate it .
The original rectifiers that were in the amp were FMG36R and 36S
Since the legs were broken and fixed with solder I replaced them with APT30D60BCAG and APT30D60BCTG.
The negative rectifier is the BCTG?
The output board is disconnected from the power supply board right now .
So I have just the power supply board sitting on the bench . I can power it up without a heatsink or I can put it back in the heatsink I just wanna let it idle for awhile to make sure no other issues arise
