So, it seems that everything is fine now
Bias adjusting, off set adjusting, amplifier playing...seems you succeed... congratulations.
regards,
Carlos
regards,
Carlos
now i test and adjust the offset on output terminal and it reads. 1.0 and my multimeter was set to 200mV. i think this is ok. any opinions?
i have a hard time in tweaking the bias (VR3), the values in my Meter continue to increase. i leave it about 600mV and now it reads 636mV. are there any problem or is this normal? the amp is almost 30mins powered on.
its working but it hums. and there is speaker pop when turning on and off. maybe i will try DX MKII or MKIII. good night folks. hope i will fix this amp next week.
Hum can be your supply filtering... or bad input coaxial cable
or because you are using MP3/4 player in the input.
There's no registered complains about hum in this amplifier...you are the first to report this.
Power on thump is normal in this amplifier.
Current drift from cold to normal operation and hot operation is normal too.
Differences of stand by current when you measure the positive rail compared to the negative rail is also normal...this amplifier sucks more current in the positive rail because of zener current you have in the positive rail
regards,
Carlos
regards,
Carlos
Hi Carlos
Nice project 😀 , Trying to build these amp , but can i use the
2SA1302 & 2SC3281
to subtitute the 2SA1943 & 2SC5200 ?
2SA1302 & 2SC3281
Yes, of course you can, they belong to the same family
2SC5200 and 2SA1943 are the next generation.... they are cousins... they are almost the same...small differences in power dissipation and other details.
No problems...will work fine and great with them.
regards,
Carlos
regards,
Carlos
hi , there are somes photographs of the pcb alone, and the populated pcb,this amp work quite well i tested it with b&w speakers ..its great,no hum , no hiss,easy to adjust as long as you follows instructions on greg web site ,as someone previously said if i can do it everyone can do it.
Very good... i am glad you made your own board
Congratulations..... it is looking good...you have made a silk screen..... that's nice.
regards,
Carlos
regards,
Carlos
its my bad that's why the amp produce hum. its because the wire i used in the input creates noise. so i wired up coaxial wire and it sound super silent. without noise and hiss. i'm very happy with this amp. i just want to try the dx mkIII-hx soon. God bless you carlos.
triple times build this amp, no error all 3 of them, happy with it, play hard also nothing burn 😛
I am glad to know that Norazmi
I do think this amplifier is very reliable.
Thank you,
regards,
Carlos
Thank you,
regards,
Carlos
It 's a NPN tranzito ,This is data sheet of its. H1061 pdf, H1061 description, H1061 datasheets, H1061 view ::: ALLDATASHEET :::What is an H1061?
Yes, you can substitute by H1061
It is cousin of the 2SC1061..... a little bit more strong but seems that belong to the same family.... you can also use TIP41C and TIP42C to all amplifier positions...i did that at home...even the differential have used TIP42C.
Result was not that good because TIP41C/42C are low speed transistors...but worked fine too.... i little bit slow i think, treble use to be better when using BD139/140.... these ones are the best sounding devices (if we can say transistor sounds), as work very well with colector voltages up to 40 volts.
Depending your substitutions you may have different adjustment to the bias trimpot, also the off set trimpot...but this will be the worst case scenario.
Be happy, enjoy, publish pictures..if you did, then publish more.
The more modern versions are more efficient as result of better construction techniques, higher speed and higher dissipation
regards,
Carlos
regards,
Carlos
But in DX amplifer schematic, only use BD 139, not use BD 140BD139 and BD140 are complementary pair this means that they have exactly the same parameters but different polarity one is NPN and the other is PNP.
In your case there is no complement according to the datasheet so it is not suitable. You can try MJE 340/350 , 2SC4793/2SA1837 , MJE 15030/15031 , TIP41/42 and so many others.
here 's result of my test voltage ,I replaced BD139 by H1061 in the schematic original , I remove all tranzito and test, but all of them is good.
Sorry , my fault. Thats why I deleted my post.
- Destroyer x Amplifier...Dx amp...my amplifier
