DAC Lampucera with Lampizator upgrade recommendations
Explanation:
I connected the new DIY DAC to my setup:
WIIM ULTRA USB → DDC → via COAX → Lampucera DAC
Unfortunately, I can no longer select the USB audio output in the WIIM app – it just doesn’t show up anymore, which means: ... no sound via USB anymore
I will have to wait until early next week: a fuse blew ... no music out of the Lampuera DAC, now I have time to fix the other Lampucera KIT with the standard tube section: all six Janzten Z-caps are in, all under the PCB with bigger standoffs.
I found a replacement fuse and reconnected the DDC via USB. Initially, I couldn't select the USB output in the WIIM app. However, after adjusting the resolution within the app, the USB output suddenly became available. Everything is working perfectly again.
Thanks for your patience @Radian / Klaus :wave2:
about the schematic ... the schematic from 2008 is still valid ... I was in touch with Srba who told me that he changed the capacitors in the signal path from miflex Mundorf silver gold oil - I did the same. Also I went with a two tube design and used JAN Philips tubes and of course the oversized power supply: three R-core transformers and a switch to be able to select Coax or optical and a separate switch (in the back) to switch between tube and opamp. I also went with high quality parts like furutech IEC and furutech RCAs ... don't know if I hear the difference but as this is probably my DIY DAC... what the heck, I went all in. This is still 5x more cost efficient compared to a Denafrips Venus 15th edition and is supposed to sound comparable - at least to the YT Lampizator Lampucera DAC guy.
