DAC-END R (ES9018) full assembled board
according post #280 I give back number 42 to la209
1. 1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp+transformers+Chassis+amanero)
5. 1 x danny_66 ( DAC base + I/V opamp + transfomer)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k92 ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + tranfomer +DAC chassis)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base)
14. 1 x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + I/V opamp + DAC chassis + trasformer + Amanero )
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base + I/V opamp + DAC chassis + trasformer)
22. gjorgji (DAC base + I/V opamp + transformer + chassis + Amanero)
23. myfavoritething (DAC base+ I/V op +chassis + transformer)
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
25. bertchai (DAC base + I/V op + chassis)
26. kimgiin (DAC Base)
27. misterrogers (DAC Base)
28. malarkey (DAC Base)
29. TarnishedEars (DAC base + I/V opamp + DAC chassis + Transformers)
30. Boxi80 (DAC base + I/V opamp + OP + transformer)
31. 1x Ridsaudio DAC Base
32. meintan (DAC base + I/Vkit + transformer + chassis)
33. Luizl (DAC base + I/V opamp).
34. inforsit (DAC base + I/V opamp + DAC chassis + trasformer)
35. xtomm (DAC base + I/V opamp + transformer)
36,37,38 3 x kgkim (DAC base)
39. necplusultra (2x tranformers)
40. 1 x halook (DAC base + I/V opamp + Amanero)
41 juju35135 (DAC base + IV opamp + chassis)
43 rliyung/raoul (dac base+chassis)
42. la1209 (DAC base + I/V opamp + Chassis + Amanero)
44. Domi_78 (DAC base + Chassis)
I missed Domi78's update
44. Domi_78 (DAC base + I/V opamp + Chassis)
No problems - happy to get another transformer. However, does the controller support standby and an external relay? I think one of your other controllers did? How about an option (perhaps a daughter board) to implement standby, a trigger output and remote in/out? Would be absolutely fantastic.
No big issue - have that impemented in my previous preamp. Just a small doughterboard with PS for the controller and RemoteIn/Out optos. The controller in standby (some 10 microA only, LCD dimmed) lurking for waking signal via IR or RemoteIn, the rest switched off. After wake up the preamp caters RemoteOut signal for HTPC and poweramp. Everytning optocoupled, safe and flexible - no relays. A killing impementation indeed - you just see the whole rig going up and sleep again with just single touch of remote - oooh...;-)
Fantastic! How do I do it?
No big issue -... controller in standby (some 10 microA only, LCD dimmed) lurking for waking signal via IR or RemoteIn, the rest switched off. After wake up the preamp caters RemoteOut signal for HTPC and poweramp. Everytning optocoupled, safe and flexible - no relays...
1. Controller must be modified: SW (subroutines for RemoteIn interrupt and standby) and HW (one I/O reserved for RemoteIn and ideally broke-out on connector. It could be just tapped later as well but if the board has not been produced yet...)
2. Control circuit: could be designed universally for optos or relays (optocouplers are somehow clean but relays could be more universal if the rest of the rig is not known yet).
3. Doughterboard design: dtto.
Nice is, that the controller could be modified as standard at no cost and the whole functionality with the doughterboard could be an option: take it or leave it...
45. 1 x chansiukwing ( DAC base )
46. Erlend Sæterdal ( Dac base )
Hi, Quanghao!
Just added my name to the list approved by quanghao.
47. CAAD (DAC base + I/Vkit + transformer + chassis + Amanero)
Hi Quanghao,
I need to join this very interesting project.
I've paid USD 375 for first pay:
- DAC base (USD 450)
- I/V stage (USD 60)
- R-Core Transformer (USD 40)
- Chassis (USD 100)
- Amanero USB-I2S module (USD 100)
Total amount: USD 750
50% = USD 375
Thank you,if any problem please let me know.
Morten
Hello Quanghao
Just to updat my orders :
36,37,38,39 4 x kgkim (DAC base), IV stage x 1ea, Amanero USB-I2S module x 3ea
40. necplusultra (2x tranformers)
41. 1 x halook (DAC base + I/V opamp + Amanero)
42 juju35135 (DAC base + IV opamp + chassis)
44. la1209 (DAC base + I/V opamp + Chassis + Amanero)
45. Domi_78 (DAC base + I/V opamp + Chassis)
46. 1 x chansiukwing ( DAC base )
47. Erlend Sæterdal ( Dac base )
48. CAAD (DAC base + I/Vkit + transformer + chassis + Amanero)
I've been paid 1,080 USD through PayPal.
The kit:
1. The kit DAC Base x 4ea
2. The Kit IV stage x 1ea
3. Amanero USB-I2S module x 3ea
Total : 2,160 USD, First prepaid : 1,080 USD
Many Thanks.
49. bobkojek (DAC base + I/V opamp + transformer )
Ups I need ( I/V + Chassis+ Amanero+ Trafo ) too. I will send 375 dollar right now.
